Go Back   Home > Forums > Amplifiers > Class D
Old 11th February 2011, 07:43 PM   #1
Default car amp inverter trafo
i'm trying to build a car amplifier.
i have all of it figured out but i got stuck with two intefearance filters and the trafo.
here are the schematics for the inverter:
http://imageupload.org/?di=212967817272
http://imageupload.org/?di=012967817284
http://imageupload.org/?di=0129678172810
and here is the hole patterns that i have:
SP1:Click the image to open in full size.SNT1:Click the image to open in full size.DR1:Click the image to open in full size.
the trafo works @70kHz (or 75kHz, my calculations may not be correct!)
pumps it from 12 to +- 24 volts and it powers 4X75W rms @4 ohms or 2X250W rms @ 4 ohms.
my german isn't great so i think the core is 30X20X10mm that is S=1 sqr_cm
and they say i should use 0.5mm wire (in bundels) and i need 6,1meters of wire total
also it says "1+2e spannung" on the secondary.
Thanks!
most powerful class D for car without inverter jaya000 Class D 34 25th April 2011 03:34 AM
Power supply options.. bigger trafo with less caps or medium trafo with heavy caps? rhythmdiy Chip Amps 9 23rd October 2007 12:30 AM
moddifying power inverter for amp soundNERD Car Audio 11 5th June 2005 02:20 AM
Trafo to buy for PWM amp partyjups Solid State 6 19th December 2001 10:32 PM
Page generated in 0.06313 seconds (69.54% PHP - 30.46% MySQL) with 10 queries
