Class D Amp with LM566,LM393 and 2XIRF530 - Page 57 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 29th March 2014, 09:21 AM   #561
Originally Posted by apexaudio View Post
D200.1
hi Apex,
can I ask for PCB lay-out for D200.1? I would like to build your class d amp..
thanks..
Old 31st March 2014, 07:01 AM   #562
Originally Posted by QQ12e5k1 View Post
Dear Mile..
Please check maybe there some error on my pcb.
sir QQ,
can I ask your PCB lay-out of d200.2. I would like to build d200.2.
thanks...
Old 31st March 2014, 11:32 AM   #563
stewin is offline stewin  Kenya
Originally Posted by stewin View Post
hi sir apex
can i use +\-80vlts with a 2ohms load if i use irfb4227 as outputs ?
and how many turns have you used in the toroid t-106 2 output inductor?
thanking you in advance steve
any idea anyone?
Old 25th April 2014, 07:06 AM   #564
hi apexaudio,
ml3 is not working with d class making strange noise en increasing the vol same wen increasing treble.tested with irs1500 as well the same situation.
thanks
ravs......
Old 9th May 2014, 05:55 AM   #565
cook77 is offline cook77  Romania
Can you tell me what is the size of the PCB?
I tried D200 pcb and couldn't match CI pins with pcb's holes. My pcb is 15/6,5 cm. There are two ways of facing 2n5401&78l05 ; Which one is ok?
Ifound this amp on other forum but I can't understand (even using google translate )
Old 11th May 2014, 08:36 AM   #566
I found out. It's 52mm X 120mm
Old 11th May 2014, 09:22 AM   #567
Hi Apex & DIYer,
Can I use inductors from COILCRAFT - VER2923-223KL?
any ideas???
Old 11th May 2014, 09:33 AM   #568
Send a message via Yahoo to ionutzxpo
hi dc sound, you can use them, they are made for audio
Iacob Ionut
Old 11th May 2014, 09:42 AM   #569
thanks for your reply...
Old 19th May 2014, 08:58 PM   #570
Did anyone finished APEX D200.2 ,test it, and can say: It's OK?It's working!
D200;D200.1 report OK.how about this one?
Configuring an AB class amp to work in pure A class jrme Tubes / Valves 5 23rd February 2010 07:31 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 08:52 PM
why p-p amp RL for class B is 1/2 the class A load? walter33333 Tubes / Valves 2 12th February 2008 05:56 PM
Class D amp? Digital amp? or traditional Class A? rockytro Solid State 21 23rd May 2006 01:40 AM
Copyright 1999-2017 diyAudio
