Class D Amp with LM566,LM393 and 2XIRF530 - Page 53 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 30th March 2013, 05:01 PM   #521
apexaudio's Avatar
D200 on SMPS
Smps & Apex D200 - YouTube
Old 30th March 2013, 05:12 PM   #522
apexaudio's Avatar
Originally Posted by jlester87 View Post
Hi Azmi,
I've traced the circuit for the protection. It uses 2 of the NAND gates(pins 1 to 6) for shutdown control, the input for the pins 1 and 2 of 74HC00 (encircled in the attached pic) is normally "low", when there's a voltage across the current sensing resistor, pins 1 and 2 will go "high", resulting pin 6 to output high then triggers the SD pin of IR2110.
But there's no delay for the trigger, the 47uf connected in pin 5 is only for startup delay.
I'm afraid the protection will loop fast (assuming current sensing in speaker out works) and might lead to mosfet destruction.
Protect have delay with 2k2 and 220pF for activate, 47uF and 10k for startup delay is also for protect release delay.
Old 3rd April 2013, 12:59 PM   #523
PetruV is offline PetruV  Romania
I am no longer building this amp,its very complicated so im going with an apex b500.
It seems as this thread lost popularity when i stopped posting
Just a kid who likes building and modding things.No inspirational quote here for you
Old 6th April 2013, 01:14 PM   #524
44250 is offline 44250  Serbia
44250's Avatar
Send a message via AIM to 44250
that's too bad,because you contributed so much to this thread...
i have decided to try this amplifier,i have read this thread from the page 43 up to here but will not start assembling it untill i read it from a page 1.
Old 10th April 2013, 08:54 AM   #525
its one heck of a chalenge to build these ,so make sure you are prepared not like me who put it aside since it requires too many parts
Old 10th April 2013, 04:24 PM   #526
44250's Avatar
there are not so many parts in this amplifier,but main thing that can be an opsticle is if it doesnŽ t work from first plugging in i am in trouble because only thing that i can do is to measure the frequency and current/voltage by my DMM - i also donŽt have osciloscope. all i can do is to read this thread and hope for the best. more than a few people did it,i hope to be one of them...
Old 10th April 2013, 06:09 PM   #527
yep know that feeling,it happens a lot to me,if it dosent work no one can help you,i tried building many amps but only one worked,for the others people didnt know how to help me
Old 10th April 2013, 06:24 PM   #528
44250's Avatar
i have built 10 amplifiers up till now,all ab and one b-class and all of them work well as they should. d-class is something a bit new to me and more demanding one-from tehnical point of view and from needed equippment point of view.
i will try it,so we will see what will happenŽ.
Old 17th April 2013, 10:33 AM   #529
Good look,were your amps on pcbs like these or on perfboard?
Old 17th April 2013, 02:37 PM   #530
norazmi is offline norazmi  Malaysia
use main supply in series with bulb when first time power on . btw if your component is the same what apex showing and mount them correctly, dont be rush, check every component and trace, im sure this amp will work nicely. most ppls do modified with another value component because they dont have exactly component listed by apex, so there is the problem, when u want build class D amp who already testing and running, you need to have commitment for all part list with the same value and type.
p/s - there is no shortcut to make it more easy
Configuring an AB class amp to work in pure A class jrme Tubes / Valves 5 23rd February 2010 07:31 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 08:52 PM
why p-p amp RL for class B is 1/2 the class A load? walter33333 Tubes / Valves 2 12th February 2008 05:56 PM
Class D amp? Digital amp? or traditional Class A? rockytro Solid State 21 23rd May 2006 01:40 AM
Copyright ©1999-2017 diyAudio
