Class D Amp with LM566,LM393 and 2XIRF530 - Page 44 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 8th March 2013, 09:27 PM   #431
krakow is offline krakow  France
Originally Posted by apexaudio View Post
Amp can't work with +/-12V, I use +/-38V minimum rail voltage and +/-80V maximum with IRF640N for test.
Ok, sorry for my error, is not TIP640 but IRF640, you're right ;p
Old 9th March 2013, 09:03 AM   #432
apexaudio's Avatar
You can use IRF540N for rails under +/-40V.
Old 9th March 2013, 10:30 AM   #433
Ok. What is the power with IRF540N at +/-30V into 4 and 8 Ohm ?
Old 9th March 2013, 05:40 PM   #434
apexaudio's Avatar
About 100W into 4 Ohms.
Old 9th March 2013, 06:40 PM   #435
PetruV is offline PetruV  Romania
Pdf layout for d200.2 ?,im really building this at 90 v along with a smpsu
Also has anibody did a different layout with the mosfets at the side of the board so they can be mounted to a heatsink,since i want them mounted to a heatsink,a big one with a fan,a long tunnel cooling the modules and the smpsu transistors
Just a kid who likes building and modding things.No inspirational quote here for you
Old 10th March 2013, 08:44 AM   #436
I also heard that using a bigger output inductor [180uh] makes amps sound better,is it the case with thiss one,or does it break it
Old 10th March 2013, 10:32 AM   #437
de Ocampo's Avatar
Sir Mile,
3 questions here;
1) At -/+42vdc (30vac traffo) PSU, do I have to reduce 4.7k 2w limiting resistors supplying the 5.6v zeners?
2) I have here a TIP117 can I also use this for the bias regulator instead of IRF640?
3) I cannot find a 0.1ohm 2 watter resistor (current sensing) and the closest I can get was rated 0.5ohm 2w. Will this work as well?
Thank You!
Old 11th March 2013, 02:46 PM   #438
apexaudio's Avatar
Originally Posted by abetir View Post
Sir Mile,
3 questions here;
Thank You!
1) Use 2k2/2W
2) Yes use TIP117 with 13V zener
3) Use 0.05ohm/2W or 10x0.5ohm/2W in parallel
Old 12th March 2013, 04:58 AM   #439
de Ocampo's Avatar
Here's my D200v2 build, it still needs a few parts to make it complete....
Old 12th March 2013, 07:30 AM   #440
Nice work,i hope it works good
Configuring an AB class amp to work in pure A class jrme Tubes / Valves 5 23rd February 2010 06:31 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 07:52 PM
why p-p amp RL for class B is 1/2 the class A load? walter33333 Tubes / Valves 2 12th February 2008 04:56 PM
Class D amp? Digital amp? or traditional Class A? rockytro Solid State 21 23rd May 2006 12:40 AM
Copyright 1999-2017 diyAudio
