Class D Amp with LM566,LM393 and 2XIRF530 - Page 40 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 28th February 2013, 10:55 PM   #391
Originally Posted by apexaudio View Post
This D200 work at +/-80V rail, only 2k2/2W and TIP31C are hot.
It start at very low input signal without any audable noise.
why twist the coil so little? it's not a T106-2...
Regards.
Old 28th February 2013, 11:04 PM   #392
krakow is offline krakow  France
Regards.
I think that coil come from Behringer.
Old 1st March 2013, 08:39 AM   #393
apexaudio's Avatar
Originally Posted by PetruV View Post
I seen the d500 but its too complex i want something like d200 but 500-700w
You have no expirience in meaking amplifiers, I suggest you to build D200 as your first amplifier and if work...
Old 1st March 2013, 08:43 AM   #394
apexaudio's Avatar
Regards.
It's ferite core with gap from Behringer class D amplifier. Many ferite cores with gap can be use instead T106-2 but with 15-20 turns for 30uH.
Old 1st March 2013, 10:45 AM   #395
Thank You for the explanition sir, i will try using ferite with gap next day.
Regards.
Old 1st March 2013, 10:58 AM   #396
try using IRFP240 to compare with IRF640 with same voltage and coil 51 turns. BTW can BAT 86 instead BAT 85, sir ?
Old 1st March 2013, 02:32 PM   #397
apexaudio's Avatar
Use 1N4148 instead BAT85.
Old 2nd March 2013, 01:43 PM   #398
PetruV is offline PetruV  Romania
Cant
IRFB4227 be used for 500w in d200?,anything else for even more power?,will they be ok for 2 ohms
Old 2nd March 2013, 03:04 PM   #399
Will irfb4227 at 75v work at 2 ohms,that will get me 800w
Old 2nd March 2013, 03:49 PM   #400
apexaudio's Avatar
Use IRFB4229
http://www.irf.com/product-info/data...rfb4229pbf.pdf
Configuring an AB class amp to work in pure A class jrme Tubes / Valves 5 23rd February 2010 06:31 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 07:52 PM
why p-p amp RL for class B is 1/2 the class A load? walter33333 Tubes / Valves 2 12th February 2008 04:56 PM
Class D amp? Digital amp? or traditional Class A? rockytro Solid State 21 23rd May 2006 12:40 AM
Copyright 1999-2017 diyAudio
