| Class D Switching Power Amplifiers and Power D/A conversion |
#31 | |
I guess, this both IC models from SGS-Thomson are available for a long time:
TDA7492 http://www.st.com/internet/com/TECHN...CD00244535.pdf Distortion Tests - HifimeDIY T2 / LJM L20D / SURE TDA7498 TDA7498 http://www.st.com/internet/com/TECHN...CD00205863.pdf Sure Electronics -- New low cost 25w-100W board SMSL SA-50 - Verstärker, Lautsprecher, Zubehör - Analog-Forum Quote:
http://www.intersil.com/data/fn/fn2864.pdf Last edited by tiefbassuebertr; 14th November 2011 at 09:57 AM. |
#32 |
supplement to last post (ICL8038):
Intersil's application note "ANO13.1": http://www.intersil.com/data/an/an013.pdf |
#33 |
I can't find simple 'diy frendly' functional amp on this forum... this is JBL full bridge 500W amp with TL072, IR2111 and 4xIRFP250, work good with 18inch PA sub. Next is CREST clone with NE5532, LM319 and IR2113...
http://apexaudio.rs/ |
#34 |
Hi Apex, if you ever decide to go deeper into class D, use this one as a reference, it's state of the art unlike the other stuff posted.
I use to feel like the small child in The Emperor's New Clothes tale
#35 | |
http://apexaudio.rs/ Last edited by apexaudio; 17th November 2011 at 06:47 PM. |
#36 | |
Building a 1000W @ 8ohms class D amplifier from zero there is also to find an interesting approach. Actually it would be helpful to create a Class-D evaluation board, to find out the pros and cons of various topologies and sample rates - with discrete devices of course (or quasi-discrete with standart ICs like drivers, comparators, VCO's and operational amplifier). Who is able to develope such an evaluation board? |
#37 | |
Stay tuned...
You don't need a weatherman to know which way the wind blows --Bob Dylan |
#38 |
JBL new class D amp
http://apexaudio.rs/ Last edited by apexaudio; 18th November 2011 at 11:33 AM. |
#39 |
Triangle oscillator from FBT
#40 |
Error amp, triangle osccilator, comparator ...
| Configuring an AB class amp to work in pure A class | jrme | Tubes / Valves | 5 | 23rd February 2010 06:31 PM |
| Can a Class AB PP amp be said to be operating in Class A at low signal levels? | ray_moth | Tubes / Valves | 19 | 23rd January 2009 07:52 PM |
| why p-p amp RL for class B is 1/2 the class A load? | walter33333 | Tubes / Valves | 2 | 12th February 2008 04:56 PM |
| Class D amp? Digital amp? or traditional Class A? | rockytro | Solid State | 21 | 23rd May 2006 12:40 AM |
