| Class D Switching Power Amplifiers and Power D/A conversion |
#381 |
It's over 100W at 4R load with +/-42V DC.
http://apexaudio.rs/ |
#382 |
#383 |
#384 |
I want to supplied my amp about 2*40v.
So with 2*30v transfo it's ok (30*1.414=42.5v)(42.5-2.4=40v) 2.4 is the loss in the diode bridge. But I have a problem to select the power of the transfo ! I think 200W it's ok because the amp can "give" 100W+ the heat loss (30w)+the loss in transfo(40w)=170w (30w of margin). What do you think ? |
#385 | |
#386 |
Ok, thanks
Regards |
#387 |
for apex d200 what trafo and what transistors for 500-700w
#388 |
D200 is 200W amplifier.
#389 |
#390 | |
And 500W is a very high power, it must have many security control. The D500 is not so complex in front of D200 and it was design for 500W ! |
| Configuring an AB class amp to work in pure A class | jrme | Tubes / Valves | 5 | 23rd February 2010 06:31 PM |
| Can a Class AB PP amp be said to be operating in Class A at low signal levels? | ray_moth | Tubes / Valves | 19 | 23rd January 2009 07:52 PM |
| why p-p amp RL for class B is 1/2 the class A load? | walter33333 | Tubes / Valves | 2 | 12th February 2008 04:56 PM |
| Class D amp? Digital amp? or traditional Class A? | rockytro | Solid State | 21 | 23rd May 2006 12:40 AM |
