Class D Amp with LM566,LM393 and 2XIRF530 - Page 35 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 17th February 2013, 06:29 PM   #341
exflaco is offline exflaco  Armenia
Irs900 a hunded plates are wrong ? i have many class d amps working a gapped ferrite core ,the point its help to people to make a class d amp cheapper and safety (sorry bad englis)the gap must be only internall in ee core and 1-2mm ee-ei from old pc smps work
Old 17th February 2013, 06:35 PM   #342
Khalsa take a look a Tienchai and Irvynejay post here in class d forum a Triell amp
Old 17th February 2013, 07:51 PM   #343
hi
i can not creat IRS1500
can you help me for creat this amp please ?
Old 18th February 2013, 11:05 AM   #344
Hy Hardi wath pcb use you?
Old 18th February 2013, 01:27 PM   #345
Originally Posted by lycanlk View Post
No. Ferrite cores are not good as the output inductor here. It will heat up like a burning coal. Just try it and have fun
T106-2, T157-2 or any -2 iron powder cores are ideal.
T106-2
regards
Thank's for the reply sir.
Old 18th February 2013, 07:02 PM   #346
i dont know clearly
i creat 2 pcb for IRS1500
2 pcb for IRS900
1 pcb for IRS2000
and 1 pcb for IRS3000
no one was not worked
Old 18th February 2013, 07:03 PM   #347
if you have corect PCB for IRS1500 please share it to me
thanks
Old 18th February 2013, 11:11 PM   #348
de Ocampo's Avatar
@ IRSound,
Will you be kind enough to share your pcb bottom copper for etching...my acquired film caps does not fit on Sir Miles pcb artwork.. I think we are using the same type of film caps. Your D200 is now working, am I right? Too bad my desktop failed last Sunday..hard disk failure. I can't work on my CAD files
Regards!
Old 19th February 2013, 07:47 AM   #349
wiljj78 is offline wiljj78  Philippines
wiljj78's Avatar
Ferrite core with gap work very well lok at irs900 original or this
Cool amp! is this tested and working circuit?
Old 19th February 2013, 05:29 PM   #350
Originally Posted by abetir View Post
@ IRSound,
Regards!
not enough space for those caps, same problem with me....
Configuring an AB class amp to work in pure A class jrme Tubes / Valves 5 23rd February 2010 06:31 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 07:52 PM
why p-p amp RL for class B is 1/2 the class A load? walter33333 Tubes / Valves 2 12th February 2008 04:56 PM
Class D amp? Digital amp? or traditional Class A? rockytro Solid State 21 23rd May 2006 12:40 AM
Copyright 1999-2017 diyAudio
