Class D Amp with LM566,LM393 and 2XIRF530 - Page 3 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 14th February 2011, 01:43 AM   #21
nigelwright7557's Avatar
Originally Posted by apexaudio View Post
Feedback is only for DC servo on this amp.
Thats a smart move as the DC can move around a bit until the amp warms up.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk
Old 14th February 2011, 07:31 PM   #22
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Originally Posted by nigelwright7557 View Post
I did a similar project using a TL082 triangle wave generator, LM319 comparator, XOR gates phass splitter and IR2113 mosfet driver.
I didnt use any feedback at all yet it sounded great.
The only minor problem I found was I needed to null the DC offset using a pot or i got low level hum. Must have been an inaccuracy somewhere in the line.
If you don't use any feedback, PSRR becomes 0dB. Ripple from supply rails appears directly at the ouput.
I use to feel like the small child in The Emperor's New Clothes tale
Old 24th April 2011, 12:21 PM   #23
This JBL class D amp for subwoofer can be made without SMD parts.
have you try this amps?
what is the supply voltage?
Old 26th April 2011, 09:57 AM   #24
apexaudio's Avatar
No, but JBL any many other brands use this class D module in active subwoofers...,
Old 11th November 2011, 10:15 AM   #25
apexaudio's Avatar
Triangle Oscilator with NE555, out can be connect to pin 5 of LM393.
Old 11th November 2011, 03:05 PM   #26
tiefbassuebertr's Avatar
Perhaps the regulated power supply of the Linn power amp model "Klout" is helpful (have a look to the attachement).
LM566 VCO seems unobtainable.
here a German supplier:
SE566H A15/2475 - SH-Halbleiter Electronic Vertrieb GmbH
According the internal - not too complicated circuit - go to the datasheets about
http://www.datasheetcatalog.org/data...6/53609_DS.pdf
and
NE566N datasheet pdf datenblatt - NXP Semiconductors - Function generator ::: ALLDATASHEET :::
it must be easy possible to create the wanted functions with discrete decices.
Old 11th November 2011, 07:14 PM   #27
RaiTulo is offline RaiTulo  Finland
and
Or ICL8038 ICL8038
Detailed Schematic page 4
Old 13th November 2011, 05:00 PM   #28
baga is offline baga  Romania
I dont't understand why someone will make a 25w discrete class d amplifier, apart from learning. There are many integrated circuits with better performance.
Old 13th November 2011, 06:15 PM   #29
I understand this. The reason is the unknown time of availability. Most Class-D IC's in currently day's are obsolete and no longer available after very few years.
Otherwise brands like B&O (ICEPOWER), Hypex (UCD) and several others
would prefer monolithic IC's instead discrete solutions.
An second reason could be the possibility of detail improvements while the current production.
Old 14th November 2011, 09:21 AM   #30
Icepower and Hypex make discrete amplifiers because they want to achieve higher power and lower distortions than those of the integrated circuits. And they don't make with lm393 and irf530
This schematic have low power and high distortions because of that parts, feedback topology and bad pcb layout. It has poorer performance than most integrated circuits. And is more difficult to make Only drawbacks, for what?
You are right about that some integrated circuits get obsolete, but we talk there from the point of view of a diyer. If some integrated circuit will get obsolete, we can simply pick another ic for our amplifier project. We don't have to modify our production line.
JBL and others use something like that in some products because were designed many years back. In those years that was the level of class d and they didn't have many integrated circuits.In 2011 , this schematic is a shame for class d.
Anyway, if you want to make a discrete amp,is better to make something like um10155 or with irs2092. For those you find a good pcb layout in the application notes. Theese have low distortions and can be scaled for higher power. You will get way better performance than this junk.
Configuring an AB class amp to work in pure A class jrme Tubes / Valves 5 23rd February 2010 06:31 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 07:52 PM
why p-p amp RL for class B is 1/2 the class A load? walter33333 Tubes / Valves 2 12th February 2008 04:56 PM
Class D amp? Digital amp? or traditional Class A? rockytro Solid State 21 23rd May 2006 12:40 AM
Copyright 1999-2017 diyAudio
