Class D Amp with LM566,LM393 and 2XIRF530 - Page 29 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 31st January 2013, 12:49 PM   #281
apexaudio's Avatar
Originally Posted by Nagark View Post
woking in full power ??
Full power with +/-50V but only short time for test, mosfets need heatsink to work long time at full power.
Old 31st January 2013, 04:20 PM   #282
IRSound is offline IRSound  Germany
Mile,
Did you measure FSW with scope before filter ? first time i measured it wasn't 450K. it was 170KHz.
Old 31st January 2013, 04:46 PM   #283
apexaudio's Avatar
Originally Posted by IRSound View Post
Mile,
It was 430kHz, can you change FSW with pot on your amp?
Old 31st January 2013, 07:11 PM   #284
yes , i could at that time. but after changing feedback network with single 100k resistor like detex amps. now days i'm working on another design.(DETEX IRS + APEX D200)
i think detex irs series amp have some problems in design which i wasn't found them on your amp. (watch my irs-1500 test video) now i want to mix them to achieve a better design.
also high temp is almost ok. but we need to choose the best value for R gate to reduce switching losses. using IRFB4227 or simillar fets which need high current gate drivers isn't good for IR2110. more IR2110 heating and more switching losses.
Old 31st January 2013, 08:11 PM   #285
apexaudio's Avatar
D200 is basic design and can be upgrade with gate drivers... what do you want use from detex irs?
Old 31st January 2013, 09:21 PM   #286
Nagark is offline Nagark  Brazil
Send a message via ICQ to Nagark Send a message via MSN to Nagark Send a message via Skype™ to Nagark
And if you try to put a small piece of aluminum on top of the ci
might have some positive result
but in my opinion it would be better to change the project and try to implement a discrete drive circuit
Any problem with grammar please complain to mr google translator
Old 31st January 2013, 11:39 PM   #287
first time i run the D200 , it have some problems , maybe because of changing PCB or part mistakes. but after some changes , it starts working with no problem. i set that trimpot for having 250KHz before filter.
I test both D200 and IRS-1500D. in my tests , IRS have some problem before starting oscillation. when we apply voltages to the amp , IRS doesn't start oscillation and active LED is off. just like your amp (check on scope) , also your amp doesn't start oscillation before apply input signal.
but the first problem with lowest level input is a little noise can be hear form IRS. i uploaded a video on my channel @ youtube about that.
after applying input to the amp , your amp start oscillation and there is no problem but 4227s get warm maybe due to their high Ciss or low gate charging current. so as i mentioned before , temp rising was my problem.
but in IRS , like the video , when i increase the source volume up to 5% it wasn't oscillate in correct way. i couldn't understand why and no ones tell me about that !
but after 8% volume , active LED bright constantly and amp start to oscillate @ 250KHz and everything will be ok after that. i don't know it's my problem or another people have same problems.
- I think the IRS problem is CD4049(VCC) and IR2110(VDD) supply. in your amp they're connected to a +5v line via 78L05. but in IRS they're connected to +12v bias via 100 Ohm resistor.
what you think mile ?
Old 1st February 2013, 06:38 AM   #288
apexaudio's Avatar
You can use 74HC04 or 74HC14 instead CD4049 and supply with +5 v via 78L05.
Old 1st February 2013, 07:54 AM   #289
do you have any other recommendation about IRS problem ?
CD4049 datasheet :
Features
• CD4049UB Inverting
• CD4050B Non-Inverting
• High Sink Current for Driving 2 TTL Loads
• High-To-Low Level Logic Conversion
• 100% Tested for Quiescent Current at 20V
• Maximum Input Current of 1μA at 18V Over Full Package
Temperature Range; 100nA at 18V and 25oC
• 5V, 10V and 15V Parametric Ratings
they're CMOS , it works with 5v supply also.
Old 1st February 2013, 08:48 AM   #290
manojtm is offline manojtm  India
manojtm's Avatar
Hi IR,
74HC04 and CD4049 not a pin to pin use cd4069 is pin to pin for 74hc04.
your problem was in level shifter point(5401). adjust the resistor value for the inverter input.
for IRS900 change 4k7 to 1k5 and 6k8 to 10k
change signal input resistor 1k to 2k(pin-2 of TLO71)
regards
MANOJ
Configuring an AB class amp to work in pure A class jrme Tubes / Valves 5 23rd February 2010 06:31 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 07:52 PM
why p-p amp RL for class B is 1/2 the class A load? walter33333 Tubes / Valves 2 12th February 2008 04:56 PM
Class D amp? Digital amp? or traditional Class A? rockytro Solid State 21 23rd May 2006 12:40 AM
Copyright 1999-2017 diyAudio
