Class D Amp with LM566,LM393 and 2XIRF530 - Page 25 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 7th January 2013, 11:32 AM   #241
apexaudio's Avatar
Originally Posted by Hadighorbani View Post
Hi
please share a very good quality picture from your amp
i want chek your amp parts and my amp too
maybe i have problem in filter zone. right ?
thanks
D200 HQ
Old 7th January 2013, 01:05 PM   #242
manojtm is offline manojtm  India
manojtm's Avatar
where can i find difference between this two topologies ? I really want to understand how they work...but i cant find a short and good article about this..if you don't mind , please give me some lessons.
Hi IRsound,
UCD means universal class d, mainly all forum members says UCD is self oscillated type class d amp
IRAUDIO(D200 mile's) designs are Delta sigma self oscillated type class d amp this is the final version.
like Lm311,lm393 and lm319,they used both topology
(a) self osc. one
(b) carrier based one
MANOJ
Old 7th January 2013, 06:35 PM   #243
Hi sir mile
1. 0.1 ohm 2w
2. 2n5401
3. 2n5401
4. tip31c
5. 3.3k ohm
6. 100 ohm
7. 100 ohm
8. 1k ohm 2w
9. 1k ohm 2w
10. 68k ohm
11. 1k ohm 1%
i was used this part insted your parts
i use T106-2 for filter too
my mosfets are IRFP250N
what can i do ?
Old 7th January 2013, 06:38 PM   #244
sorry but i can not read part number of you IC S .
Old 8th January 2013, 12:08 PM   #245
apexaudio's Avatar
10 is 10k resistor, not 68k, there is not 68k resistor on this amp only 6k8.
Use IRF640N and 47 ohm instead 100 ohm, ICs are TL081, 74HC00 and IR2110.
Old 8th January 2013, 06:25 PM   #246
thanks
i will try but i thing i have a problem in filter section
Old 10th January 2013, 07:26 AM   #247
de Ocampo's Avatar
Sir Mile,
why is the orientation of the 2n5401 & 78L05 do not match in this given parts lay out...
Old 10th January 2013, 09:13 AM   #248
apexaudio's Avatar
Originally Posted by abetir View Post
Sir Mile,
My mistake (reverted pins), use orientation from first layout, and you can see orientation on picture in post #241.
Old 10th January 2013, 12:26 PM   #249
IRSound is offline IRSound  Germany
Unhappy My Amp not working
Hi Mile,
I design new board , because i want to change some footprints or change some capacitors to smd type...
after finishing assembly , i connect +/-44v supply and 1KHz sine wave from PC to input. but measured waves aren't familiar to me. i think my board have some problem..but i check it lots of times..i can't find it..
i attached measured waves , also a picture of my amp and layout. after extract Zip file , please read that notepad file.
please help me mile..
IRSound
Old 10th January 2013, 10:52 PM   #250
de Ocampo's Avatar
OK sir thanks, missed that one..
Configuring an AB class amp to work in pure A class jrme Tubes / Valves 5 23rd February 2010 06:31 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 07:52 PM
why p-p amp RL for class B is 1/2 the class A load? walter33333 Tubes / Valves 2 12th February 2008 04:56 PM
Class D amp? Digital amp? or traditional Class A? rockytro Solid State 21 23rd May 2006 12:40 AM
Copyright 1999-2017 diyAudio
