Class D Amp with LM566,LM393 and 2XIRF530 - Page 23 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 3rd January 2013, 11:27 AM   #221
manojtm is offline manojtm  India
manojtm's Avatar
With +/-40V power is 80W/8 Ohm load without heatsinks on IRF640 (about 300W/2 Ohm load)
Hi mile,
+/-40V Power True RMS is 88W 8R load
FTC (sqr root(200x8)=40v) is 200W 8R load
D200 work perfect with inductor from BEHRINGER class D amp, core with 1mm gap and 15 turns.
is it ferrite core?? size??
MANOJ
Old 3rd January 2013, 12:20 PM   #222
IRSound is offline IRSound  Germany
Thanks Apex ,
Hi Manoj ,
please share with us , how we can calculate output power with other voltages..
Old 3rd January 2013, 06:00 PM   #223
sir mile
what is the problme in my D200 board ?
Old 3rd January 2013, 07:16 PM   #224
apexaudio's Avatar
Originally Posted by Hadighorbani View Post
sir mile
I can't tell you without tests and measurement, but try it without O/C protect if you can't find 0,05R/5W resistor.
Old 4th January 2013, 06:15 AM   #225
manojtm's Avatar
Hi ALL
(RMS)FTC calculation is V^2/R=P
ie, 40^2/8= 1600/8=200W RMS
True RMS Calculation is [V/(2xsqroot2)]^2/R=P
(+)40V+(-)40V = 80V(total)
[80/3]^2=710.93/8=88.8W RMS
MANOJ
Old 4th January 2013, 06:48 AM   #226
manojtm's Avatar
Hi ALL
actual value for 2x Root 2 = 2.828 so i round to 3
with actual [80/2.828]^2=800/8=100W RMS
MANOJ
Old 4th January 2013, 07:36 AM   #227
hi
i am using 0.1 ohm now for test but nothing change
thanks
Old 4th January 2013, 07:42 AM   #228
thanks sir manoj
Old 4th January 2013, 11:09 AM   #229
Thanks Manoj ,
is there any difference in output power if we use regulated or unregulated smps for this amps ? because mile said that. (in example of XLS1500 amp)
generally , i want to know how much the type of power supply can change the output power...
IRSound
Old 4th January 2013, 01:23 PM   #230
manojtm's Avatar
Hi IR,
if you are using unregulated PS check voltage with maximum power then calculate with that voltage(normally 4.5V difference) .and i think all speakers are FTC RMS rated one not true RMS
MANOJ
Configuring an AB class amp to work in pure A class jrme Tubes / Valves 5 23rd February 2010 06:31 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 07:52 PM
why p-p amp RL for class B is 1/2 the class A load? walter33333 Tubes / Valves 2 12th February 2008 04:56 PM
Class D amp? Digital amp? or traditional Class A? rockytro Solid State 21 23rd May 2006 12:40 AM
Copyright 1999-2017 diyAudio
