Class D Amp with LM566,LM393 and 2XIRF530 - Page 22 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 25th December 2012, 03:43 AM   #211
merry Christmas. All affection and best wishes to you and yours.
Old 29th December 2012, 09:07 AM   #212
IRSound is offline IRSound  Germany
Hi Mile ,
Can I use BD243C instead of BD241C ?
and, using zener diodes for voltages like +/-5v and 12v isn't making problem ? because their voltages aren't stable...
for example , Mackie use regulated voltages (with ICs)..
my ps transformer have voltages about 57-0-57 @ no load..so after rectifire it should be about +/-80v @ no load , does it have any problem if i connect it to amp ?
IRSound
Old 31st December 2012, 09:49 AM   #213
Mile ,
please give me an answer...
IRSound
Old 31st December 2012, 10:59 AM   #214
apexaudio's Avatar
Originally Posted by IRSound View Post
Hi Mile ,
IRSound
BD243C or TIP31C.... and many other TO220 NPN transistors can be use instead BD241C, you can also use N mosfet like IRF540 with 15V zener instead 12V. This amplifier is for fan and make some expirience with class D amps, it's better use extra +/-5V and 12V PSU, but will work anyway.
Old 31st December 2012, 12:18 PM   #215
Thanks,
so what's the difference then ?
how about this question :
IRSound
Old 2nd January 2013, 07:13 AM   #216
manojtm is offline manojtm  India
manojtm's Avatar
Hi IR,
with full load it will down to 75V(diode voltage drop); no problem with 200v mosfet max.90V supply
MANOJ
Old 2nd January 2013, 02:25 PM   #217
aman khalsa's Avatar
m also want to make this one vry nice amp... thnk u sir
Old 2nd January 2013, 10:48 PM   #218
apexaudio's Avatar
D200 work perfect with inductor from BEHRINGER class D amp, core with 1mm gap and 15 turns.
Old 3rd January 2013, 09:26 AM   #219
Mile ,
it's yours ?
Could you please tell me about output power with +/-40v supply ?(8~2 Ohm Loads)
Old 3rd January 2013, 10:24 AM   #220
apexaudio's Avatar
Mile ,
it's yours ?
With +/-40V power is 80W/8 Ohm load without heatsinks on IRF640 (about 300W/2 Ohm load)
Configuring an AB class amp to work in pure A class jrme Tubes / Valves 5 23rd February 2010 06:31 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 07:52 PM
why p-p amp RL for class B is 1/2 the class A load? walter33333 Tubes / Valves 2 12th February 2008 04:56 PM
Class D amp? Digital amp? or traditional Class A? rockytro Solid State 21 23rd May 2006 12:40 AM
Copyright 1999-2017 diyAudio
