Class D Amp with LM566,LM393 and 2XIRF530 - Page 21 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 22nd December 2012, 09:14 PM   #201
hi sir apex and sir manoj
IRFB31N20D was finished in store
sorry for me
i use 1K 1% for OSC in sir apex amp
nothing chage
i hade problem like before
it maybe for IRF640
can i use IRFP250 ?
what about filter for IRFP250N ?
thanks
Old 23rd December 2012, 01:15 PM   #202
hi sir apex
i was used IRFP250N with 100 ohm gate resistor
sound is good
in input was used ML3 tone control
when i increase the treeble then the 10 ohm 2 watt res on amp board creat smoke
what is the problem ?
Old 23rd December 2012, 01:17 PM   #203
why D200 is not good in low FREQ ?
my sub woofer say gher gher gher in midel and hi volume
Old 23rd December 2012, 04:12 PM   #204
apexaudio's Avatar
Measure voltage on zeners, and check on your pcb if red track missing. You have to high level of HF after inductor, but can't be check without scope.
Old 23rd December 2012, 06:03 PM   #205
HI sir mile
zener voltage was 11.49 v
the red section was connected in my board.
it must be connect or not ?
i was use 1k 1% for OSC resistor
i thing it was be 250KHZ
ok?
i use T106-2 with 47 turn 0.8 mm wire for filter
Old 23rd December 2012, 06:15 PM   #206
apexaudio's Avatar
HI sir mile
ok?
It's ok must be connected, what s voltage on 5,6V zeners and offset voltage on amp out?
Remove O/C protect for test, short circuit 0,15R/5W.
Old 23rd December 2012, 06:32 PM   #207
i tuch my voltmeter prob to two leg of zener diod and it was 11.49 v
please say to me right place exactly
thanks
Old 23rd December 2012, 06:38 PM   #208
in 5/6v zener the voltage was 5.45 v
Old 23rd December 2012, 06:44 PM   #209
offset voltage in exit amp was 0.275 V after i change the 10 ohm 2watt with a new one.
Old 23rd December 2012, 06:45 PM   #210
my teransformet voltage is + - 37 VDC
Configuring an AB class amp to work in pure A class jrme Tubes / Valves 5 23rd February 2010 06:31 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 07:52 PM
why p-p amp RL for class B is 1/2 the class A load? walter33333 Tubes / Valves 2 12th February 2008 04:56 PM
Class D amp? Digital amp? or traditional Class A? rockytro Solid State 21 23rd May 2006 12:40 AM
Copyright 1999-2017 diyAudio
