| Class D Switching Power Amplifiers and Power D/A conversion |
#171 |
Hi Apexaudio
greetings interested in making your amp will FDA series mosfets be ok to use in this amp warm regards andrew lebon
[image] |
#172 | |
http://www.facebook.com/APEXaudio.MileSlakovic |
#173 |
thanks
the tone control have noise i must creat preamp with LPF with 1.5 V in exit that |
#174 |
Use XL2 active subwoofer x-over.
#175 |
450kHz is to high for FDA, use IRFB31N20D... or change frequency to 250kHz.
#176 |
xl2 have in output 1.5 v sir?
#177 |
can i use irfp 250 ?
#178 |
XL2 have 1.5V output and IRFP250 can't be use on 450kHz.
#179 |
sir manoj say test irfp250.
this mosfet can work in 1mHZ he thing. |
#180 | |
Use volume pot value 1-5k for test.
http://www.facebook.com/APEXaudio.MileSlakovic Last edited by apexaudio; 17th December 2012 at 08:04 AM. |
| Configuring an AB class amp to work in pure A class | jrme | Tubes / Valves | 5 | 23rd February 2010 06:31 PM |
| Can a Class AB PP amp be said to be operating in Class A at low signal levels? | ray_moth | Tubes / Valves | 19 | 23rd January 2009 07:52 PM |
| why p-p amp RL for class B is 1/2 the class A load? | walter33333 | Tubes / Valves | 2 | 12th February 2008 04:56 PM |
| Class D amp? Digital amp? or traditional Class A? | rockytro | Solid State | 21 | 23rd May 2006 12:40 AM |
