Go Back   Home > Forums > Amplifiers > Class D
Old 14th December 2012, 06:46 PM   #131
apexaudio's Avatar
Originally Posted by Vostro View Post
Been waiting for a Diy friendly ClassD, I can't wait till January when I'll get some time to build it
There is many diy frendly build in thread ucd 25 watts to 1200 watts using 2 mosfets , this is my version of SODA
Old 15th December 2012, 08:29 AM   #132
thanks sir
all resistor was 5% or not ?
and the pcb size please .
thanks
Old 15th December 2012, 09:00 AM   #133
apexaudio's Avatar
Originally Posted by Hadighorbani View Post
thanks sir
thanks
PCB and size is in post #123. All resistors are 5% only 510R is 1%.
Old 15th December 2012, 12:39 PM   #134
apexaudio's Avatar
Diode 4004 is UF4004 or MUR120
Old 15th December 2012, 01:55 PM   #135
Hi sir apex
you have 2 PCS resistors 2k2 2W
i must change wich one for use D200 in + - 30v ?
Old 15th December 2012, 02:15 PM   #136
apexaudio's Avatar
Hi sir apex
Replace both 2k2 resistors with 1k for +/-30v
Old 15th December 2012, 05:43 PM   #137
thanks
you have 3 PCS 2n5401 in your board
right
dont have 2n5551 ?
i was created the pcb and fixing the parts
how can i change O/C options ?
which resistors do this to me ?
thanks
Old 15th December 2012, 05:51 PM   #138
apexaudio's Avatar
thanks
right
dont have 2n5551 ?
thanks
Change O/C options with diferent value of 0R1/5W resistor, for example use 0.05R/5W for 12A.
Old 15th December 2012, 09:13 PM   #139
thanks
how can i calculate O/C resistor value ?
i need formula.
Old 15th December 2012, 09:19 PM   #140
i dont have 74hc00 , irf640 , tl081 , cap 224-250v , res 510 ohm 1% now.
i buy that tomro.
very thanks sir apex
Configuring an AB class amp to work in pure A class jrme Tubes / Valves 5 23rd February 2010 06:31 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 07:52 PM
why p-p amp RL for class B is 1/2 the class A load? walter33333 Tubes / Valves 2 12th February 2008 04:56 PM
Class D amp? Digital amp? or traditional Class A? rockytro Solid State 21 23rd May 2006 12:40 AM
Copyright ©1999-2013 diyAudio
