Class D Amp with LM566,LM393 and 2XIRF530 - Page 13 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 13th December 2012, 11:25 AM   #121
apexaudio's Avatar
Originally Posted by Hadighorbani View Post
sir apex
which type off protection have your amp ?
voltage ?
input and output ?
D200 have O/C protect, rail voltage is /-75V max. and output power 200W on 8 ohms load. I will share schematic and pcb after test.
Old 13th December 2012, 11:52 AM   #122
thanks
Old 14th December 2012, 11:19 AM   #123
apexaudio's Avatar
D200 pcb size 52.5x120mm, TO220 or TO247 fet can be use with this pcb.
Old 14th December 2012, 11:49 AM   #124
layout please sir apex
can i use this amp with + - 30 vdc ?
i use sir manoj amp now
that was perfect
thanks
Old 14th December 2012, 12:14 PM   #125
dewetw is offline dewetw  South Africa
I don't know if anybody has mentioned this already, but why not just use a IRS2092? Is basically have all built in - analogue audio preamp, pwm gen, mosfet driver, protection and more. B&W use it in their high end HT sub's.
Here is the link to the PDF: http://www.irf.com/product-info/data...ta/irs2092.pdf
They have a few reference designs on their website, complete with PCB files :-)
Old 14th December 2012, 12:23 PM   #126
apexaudio's Avatar
that was perfect
thanks
With +/-30 vdc use 1k/2W instead 2k2/2W, IRF640 instead IRFB4227 and TIP122 instead BD241C.
Old 14th December 2012, 12:46 PM   #127
apexaudio's Avatar
IR2110 is easy available and not expensive. With 74AC00 power on mute and O/C protect is add. With BD241C no need for extra 12V bias suply...
Old 14th December 2012, 02:37 PM   #128
Default thanks to sir apex
thanks sir apex
nothing else change need ?
if i change irf mosfet then it is not too need the gate resistor ?
i have tip 31 not tip122.
is this good ?
i have T106-2 too.
Old 14th December 2012, 02:51 PM   #129
apexaudio's Avatar
thanks sir apex
is this good ?
i have T106-2 too.
You can use TIP31 but replace 10k resistor with 3k3 (conected to base TIP31 and 12V zener). D200 run at 450kHz.
Old 14th December 2012, 05:58 PM   #130
Vostro is offline Vostro  South Africa
Vostro's Avatar
Been waiting for a Diy friendly ClassD, I can't wait till January when I'll get some time to build it
Configuring an AB class amp to work in pure A class jrme Tubes / Valves 5 23rd February 2010 06:31 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 07:52 PM
why p-p amp RL for class B is 1/2 the class A load? walter33333 Tubes / Valves 2 12th February 2008 04:56 PM
Class D amp? Digital amp? or traditional Class A? rockytro Solid State 21 23rd May 2006 12:40 AM
Copyright 1999-2017 diyAudio
