| Class D Switching Power Amplifiers and Power D/A conversion |
#101 |
The non ucd with tl074 you coul use filterless but only for subwoffer,coul share pcb for test tis design?
#102 |
sir Apex,the comparator ic1-1 is 2,2k to grnd the comparator ic1-2 2,2 to -12v?
#103 |
#104 |
#105 |
Mini class D amp from Elektor.
http://apexaudio.rs/ |
#106 |
With BJTs
#107 |
IR2184 can be use for gate driver.
#108 |
hi apex nice ones
can bjt and 4050 be used in class d up to +/-50vlts? also can ir2153 be used in audio applications like in the above diagram? |
#109 | |
IR2153 can be use in audio only for SMPS.
#110 |
thanks sir apex
| Configuring an AB class amp to work in pure A class | jrme | Tubes / Valves | 5 | 23rd February 2010 06:31 PM |
| Can a Class AB PP amp be said to be operating in Class A at low signal levels? | ray_moth | Tubes / Valves | 19 | 23rd January 2009 07:52 PM |
| why p-p amp RL for class B is 1/2 the class A load? | walter33333 | Tubes / Valves | 2 | 12th February 2008 04:56 PM |
| Class D amp? Digital amp? or traditional Class A? | rockytro | Solid State | 21 | 23rd May 2006 12:40 AM |
