Class D Amp with LM566,LM393 and 2XIRF530
Old 22nd March 2013, 08:51 PM   #511
PetruV is offline PetruV  Romania
They are ceramic caps so i can safely use thes round orange ones i have a lot of,i heard they are also used for decoupling so it will work
BTW wima caps are expensive,and probably imposible to find in shops,so im using my ceramics afte you give me the ok
Just a kid who likes building and modding things.No inspirational quote here for you
Old 23rd March 2013, 06:18 PM   #512
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
D200 on test
D200 JUST TEST - YouTube
Old 23rd March 2013, 07:27 PM   #513
norazmi is offline norazmi  Malaysia
what mosfet do you test apex? gate? and rail voltage?
Old 23rd March 2013, 08:04 PM   #514
apexaudio's Avatar
Not my work, this D200 made by Suryadi Achmad work at +/-45V with 10N60 mosfets.
Old 23rd March 2013, 08:33 PM   #515
oh okay, ill make it stereo for test
Old 26th March 2013, 07:58 AM   #516
joexswj is offline joexswj  Indonesia
joexswj's Avatar
Originally Posted by Tekko View Post
Or you can place an order with itead studio and get ten boards for 28 us dollars shipped, though this requires having access to the PCB gerber files, which i'd guess is a well regarded secret locked away at apex's PC. Assuming Apex dident just draw his pcb's with a picture editing program such as photoshop, ms paint or similar.
and no norazmi, you cannot use a LS series ic, the circuit assumes and requires a HC series ic which is a mosfet based ic wheres the LS series is bipolar transistor based, the LS series is also much slower.
thanks Tekko....
Old 27th March 2013, 04:00 AM   #517
JLesterP is online now JLesterP  Philippines
Anyone tested the over current protect? Will the over current in mosfet be reflected in output current sense fast enough? There's no delay after the trigger too.
Old 27th March 2013, 11:43 AM   #518
I was about to ask that
Old 27th March 2013, 02:46 PM   #519
it must have a delay after protection triger, i`ve done it before with 555 timer, 1N5401 and PC817.
Old 27th March 2013, 03:16 PM   #520
Hi Azmi,
I've traced the circuit for the protection. It uses 2 of the NAND gates(pins 1 to 6) for shutdown control, the input for the pins 1 and 2 of 74HC00 (encircled in the attached pic) is normally "low", when there's a voltage across the current sensing resistor, pins 1 and 2 will go "high", resulting pin 6 to output high then triggers the SD pin of IR2110.
But there's no delay for the trigger, the 47uf connected in pin 5 is only for startup delay.
I'm afraid the protection will loop fast (assuming current sensing in speaker out works) and might lead to mosfet destruction.
Class D Amp with LM566,LM393 and 2XIRF530Hide this!Advertise here!
Configuring an AB class amp to work in pure A class jrme Tubes / Valves 5 23rd February 2010 07:31 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 08:52 PM
why p-p amp RL for class B is 1/2 the class A load? walter33333 Tubes / Valves 2 12th February 2008 05:56 PM
Class D amp? Digital amp? or traditional Class A? rockytro Solid State 21 23rd May 2006 01:40 AM
Copyright ©1999-2017 diyAudio
