Class D Amp with LM566,LM393 and 2XIRF530 Class D Amp with LM566,LM393 and 2XIRF530 - Page 51 - diyAudio
Old 21st March 2013, 08:33 AM   #501
PetruV is offline PetruV  Romania
What driller motor should i get,more specificaly what apliance has the kind of motor that you would recomend,that one is from a printer
Just a kid who likes building and modding things.No inspirational quote here for you
Old 21st March 2013, 04:13 PM   #502
norazmi is offline norazmi  Malaysia
more work petruv if u cant get exactly center point to drill, you need to make center point with analog device like classic hand drill just to make center point then start drilling with your motor.
Old 21st March 2013, 07:47 PM   #503
i centered it better
Old 22nd March 2013, 09:13 AM   #504
What matterial do the small caps have to be and what voltage do the electrolitics have to be considering it will be used at 75v
Old 22nd March 2013, 05:27 PM   #505
which small cap? For 75vdc, better use 100v cap. For 100n or 0.1uf use non polar caps
Old 22nd March 2013, 05:47 PM   #506
Tekko is offline Tekko
Banned
For the small caps, use ones made for snubber/decoupling.
Old 22nd March 2013, 05:55 PM   #507
ceramic or film or poliester,
Thanks,but for 90v will 100v caps still be ok
Old 22nd March 2013, 05:57 PM   #508
Banned
Too small safety margin, for 90V, use 120-150V rated caps.
Old 22nd March 2013, 06:27 PM   #509
ok
but one thing still remains
ceramic or film or poliester for smaller non electolitic caps
Old 22nd March 2013, 06:38 PM   #510
Banned
I'd use X7R ones made for decoupling purposes in 1210 smd package, same ones as chocoholic uses in his system D class d amp.
But i think also WIMA MKT/FKP would work as well.
Class D Amp with LM566,LM393 and 2XIRF530Hide this!Advertise here!
Configuring an AB class amp to work in pure A class jrme Tubes / Valves 5 23rd February 2010 06:31 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 07:52 PM
why p-p amp RL for class B is 1/2 the class A load? walter33333 Tubes / Valves 2 12th February 2008 04:56 PM
Class D amp? Digital amp? or traditional Class A? rockytro Solid State 21 23rd May 2006 12:40 AM
Copyright ©1999-2017 diyAudio
