Class D Amp with LM566,LM393 and 2XIRF530
Old 23rd January 2013, 10:34 PM   #271
luizcpimenta is offline luizcpimenta  Brazil
Originally Posted by apexaudio View Post
Voltage for driver suply +15V up to -HT can be realised with this simple circuit.
Hi
Could you send me the files of this amplifier?
I need to put together a good class D amplifier for use in my sound system PA
Thank you.
Old 23rd January 2013, 11:00 PM   #272
D200 can be use with 2 ohms load without any changes, just 0.05R in O/C detect circuit, and this is full range hi-fi amp work on 450kHz, for more power increase input level with preamp.
Nice work, can you upload video on yutube?
Hi
Could I send files from your amplifier D200 so I can build one?
I need to put together a good class D amplifier for use in my PA sound system.
Thank you.
luizcpimenta@yahoo.com.br
luizcpimenta@gmail.com
Old 23rd January 2013, 11:40 PM   #273
Nagark is offline Nagark  Brazil
Send a message via ICQ to Nagark Send a message via MSN to Nagark Class D Amp with LM566,LM393 and 2XIRF530
Originally Posted by IRSound View Post
Class-D IRSound D200-V.0 Based On Apex D200 - a little music+ temperature test :
Class-D IRSound D200-V.0 Based On Apex D200 - a little music+ temperature test - YouTube
so , as i mentioned before , my amp have temperature problem
in this video , i used 48uH (5x0.5mm wire) on two stacked CSC CK270060 , the core was warm about 30~40 °C in all tests.
the loudspeaker is a 16 Ohm full-range paralleled with a 8 ohm Electric resistance wire. mosfets get hot during this test as you can see up to 50 °C.
please help me...why mosfets gets hot
IRSound
OMFG 500C
Old 24th January 2013, 09:07 PM   #274
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
D200 made by Zarko Petkovski
Apex D200 - YouTube
Old 25th January 2013, 01:49 PM   #275
lyubcho88 is offline lyubcho88  Bulgaria
lyubcho88's Avatar
Hi Mile,
Could you please upload the circuit on your D200 aplifier.
BR,
Lyubo
Old 25th January 2013, 11:57 PM   #276
Originally Posted by Nagark View Post
OMFG 500C
Boa noite.
Qual amplificador você montou?
Abraço.
Old 26th January 2013, 01:55 AM   #277
Originally Posted by luizcpimenta View Post
Boa noite.
Abraço.
Apenas fiz um comentario sobre a temperatura que o amplificador atingiu mas como assisti o video em baixa qualidade nao vi a virgula da casa decimal e pensei que fosse 550 C° desculpas
Just made ​​a comment about the temperature reached the amplifier but as I watched the video in low quality not seen the comma decimal point and thought it was 550 ° C excuses
Last edited by wintermute; 26th January 2013 at 02:00 AM. Reason: added english translation
Old 26th January 2013, 02:02 AM   #278
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
diyaudio is an english speaking forum. If you post in another language please also post an english translation.
diyaudio é um fórum de língua Inglês. Se você postar em outro idioma, por favor também colocar uma tradução em Inglês
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 26th January 2013, 09:29 AM   #279
apexaudio's Avatar
Temperature was 55 deg on mosfets without heatsink.
Old 26th January 2013, 11:46 AM   #280
woking in full power ??
Class D Amp with LM566,LM393 and 2XIRF530Hide this!Advertise here!
Configuring an AB class amp to work in pure A class jrme Tubes / Valves 5 23rd February 2010 06:31 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 07:52 PM
why p-p amp RL for class B is 1/2 the class A load? walter33333 Tubes / Valves 2 12th February 2008 04:56 PM
Class D amp? Digital amp? or traditional Class A? rockytro Solid State 21 23rd May 2006 12:40 AM
Copyright ©1999-2017 diyAudio
