Class D Amp with LM566,LM393 and 2XIRF530 Class D Amp with LM566,LM393 and 2XIRF530 - Page 26 - diyAudio
Old 10th January 2013, 11:56 PM   #251
de Ocampo is online now de Ocampo  Philippines
de Ocampo's Avatar
IRSound,
...had a glimpse of your pcb lay-out and comparing it with Apex's guess I found some errors, check them out. Red line means "cut" and Green lines means connect.
TY!
Old 11th January 2013, 01:27 AM   #252
andrewlebon is offline andrewlebon  India
andrewlebon's Avatar
[es] - Galerija: Mile Slavkovi?, APEX-audio
"It's Better to try and fail than to never know and always wonder"
Old 11th January 2013, 01:38 AM   #253
IRSound is offline IRSound  Germany
Hi abetir,
Thanks , i've just checked them.
but their are correct , re check them carefully. because i change some component direction or their place.
1-that 10Kohm resistor is for start-up mute.value is correct.
2-input pin of 78L05 should connected to +12v and 100nf cap.it's correct.
3-collector pin of 2n5401 connected to a 1K resistor. after resistor it should be connect to 4 places : 1-10pF cap 2-6K8 resistor 3-anode of 4148 4-pin 12 of 74HC00 , so all of them connected in correct point in my board.
Voltages are almost ok (+/-5v and +12v) , but that waves show something which i can't understand it.
Old 11th January 2013, 02:27 AM   #254
de Ocampo's Avatar
Hi IRSound,
Yes, good to know that they were all connected properly, I was also confused at first glance... always happen when you don't have the schematic in hand...
Regards!
Old 11th January 2013, 05:24 AM   #255
wiljj78 is offline wiljj78  Philippines
wiljj78's Avatar
Originally Posted by IRSound View Post
Hi Mile,
I design new board , because i want to change some footprints or change some capacitors to smd type...
after finishing assembly , i connect +/-44v supply and 1KHz sine wave from PC to input. but measured waves aren't familiar to me. i think my board have some problem..but i check it lots of times..i can't find it..
i attached measured waves , also a picture of my amp and layout. after extract Zip file , please read that notepad file.
please help me mile..
IRSound
Please check this, i hope this can help.
IR2110 (pin#2),100n, 10uf and 47uf must connected to ground of 78L05 transistor not in -75 rail.
Old 11th January 2013, 11:05 AM   #256
Hi Wiljj ,
Thanks for helping..
- Pin 2 of 2110 should be connected to low side mosfet source pin (or -75v) like apex pcb. but there is just a small difference in routing.also ground pin of 78L05 should be connected to -75v rail. (like apex schematics via jumpers). so my board is correct in this ways.
does anyone knows anything about waves ? (which i attached them in previous page)
i also connect 33uh filter , i have 165khz sine wave with no input !!
Old 11th January 2013, 12:42 PM   #257
wiljj78's Avatar
Hi Wiljj ,
You're right, i just notice lately when i compare the component guide vs. PCB that there some difference of tract routing after the PCB was posted, my mistake, pls. ignore my post.
All the best.
Wiljj78
Old 12th January 2013, 09:25 AM   #258
manojtm is offline manojtm  India
manojtm's Avatar
Hi mile,
mackie SRM450 shematic shows one inverting buffer amp was provided in input. Without this your amp(D200 and others IRS900 etc.. ) out put is 180 degree out phase. Did you check this??
MANOJ
Old 12th January 2013, 10:35 AM   #259
Hi Manoj,
i attached a mixed schematic of previous pages..D200 schematic should be something like this , also it have some zener diode based supply for +/-5 and 12v.
did you see my attached files of first test ? what you think ?
Old 12th January 2013, 11:28 AM   #260
manojtm's Avatar
Hi IR,
pls check IR2110 pins correct or not(picture shows some mistake)
all rounded marks are connected to -ve supply rail
Remove R17 and R7 . Use 2W for R175
MANOJ
Class D Amp with LM566,LM393 and 2XIRF530Hide this!Advertise here!
Configuring an AB class amp to work in pure A class jrme Tubes / Valves 5 23rd February 2010 06:31 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 07:52 PM
why p-p amp RL for class B is 1/2 the class A load? walter33333 Tubes / Valves 2 12th February 2008 04:56 PM
Class D amp? Digital amp? or traditional Class A? rockytro Solid State 21 23rd May 2006 12:40 AM
Copyright ©1999-2017 diyAudio
