Class D Amp with LM566,LM393 and 2XIRF530
Old 6th January 2013, 09:53 AM   #231
apexaudio is offline apexaudio  Serbia
apexaudio's Avatar
Default D200 +/-75V
With +/-75V DC rail voltage 2k2/2W are very hot, but it's ok. BD241C must have heatsink.
Old 6th January 2013, 01:44 PM   #232
IRSound is offline IRSound  Germany
Mile ,
This is your own amp ?
which mosfet did you use for +/-75v ? how was the sound and quality then ?
it's beter to use 3W instead of 2W !
i found some amps on Russian language forums , with LM311 instead of TL081 and some difference in design , did you see them ?
Old 6th January 2013, 05:32 PM   #233
apexaudio's Avatar
Originally Posted by IRSound View Post
Mile ,
I use IRF640N for test with 8 ohms speaker, sound is hi-fi quality and mosfets is just warm without heatsink (work at over 100W ).
Russian amp is UCD topology and D200 is IRAUDAMP1 topology.
Old 6th January 2013, 07:07 PM   #234
Hadighorbani is offline Hadighorbani  Iran
Hi
can you use D200 for subwoofer without problem ?
Old 6th January 2013, 09:24 PM   #235
Thanks Mile ,
where can i find difference between this two topologies ? I really want to understand how they work...but i cant find a short and good article about this..if you don't mind , please give me some lessons.
i'm going to build this amp , as soon as possible !!
IRSound
Old 6th January 2013, 09:34 PM   #236
exflaco is offline exflaco  Armenia
Irsound could share these russian page links? thanks.
Old 6th January 2013, 09:57 PM   #237
apexaudio's Avatar
Originally Posted by Hadighorbani View Post
Hi
Yes, sound is very powerfull on sub.
Old 6th January 2013, 10:55 PM   #238
Irsound could share these russian page links? thanks.=
Hi Exflaco , i found that picture in google image search. i don't remember which forum was it.
but i think mile upload their schematic before. LM311+74AC00+IR2110
he changed modulator section with mackie. i upload those schematics for you.
why you aren't try D200 ?
mile , i forgot to ask another question..why you aren't put large electrolyt capacitor behind fets ? because of bus pumping effect..IRF always use this caps in their designs. or other project like irs series , etc.
IRSound
Old 7th January 2013, 10:08 AM   #239
Default Hi sir mile
Hi
please share a very good quality picture from your amp
i want chek your amp parts and my amp too
maybe i have problem in filter zone. right ?
thanks
Old 7th January 2013, 11:15 AM   #240
apexaudio's Avatar
IRSound
With my PCB design no need for large electrolyt capacitor behind fets on pcb just in PSU, and I use 470nF and 2X 220nF on pcb.
Class D Amp with LM566,LM393 and 2XIRF530Hide this!Advertise here!
Configuring an AB class amp to work in pure A class jrme Tubes / Valves 5 23rd February 2010 07:31 PM
Can a Class AB PP amp be said to be operating in Class A at low signal levels? ray_moth Tubes / Valves 19 23rd January 2009 08:52 PM
why p-p amp RL for class B is 1/2 the class A load? walter33333 Tubes / Valves 2 12th February 2008 05:56 PM
Class D amp? Digital amp? or traditional Class A? rockytro Solid State 21 23rd May 2006 01:40 AM
Copyright ©1999-2017 diyAudio
