class d for underwater transducer class d for underwater transducer - diyAudio
Old 9th February 2011, 11:51 AM   #1
volkantr is offline volkantr  Turkey
Default class d for underwater transducer
Hi everybody,
this is my first message to the forum, this is a really vital area for newbies like me.
my problem that I need your help is about class d
I designed a power amplifier for driving an underwater transducer, because the linearity is important I preferred class AB topology but as you know it heats so much and need bigger heatsinks so in the end that starts to be a mechanical problem (not enough space for the heatsink). I decided to use a class D amplifier. but I'm a starter for switching amplifiers. my design will be a little bit different from audio amplifiers (I'll work between 10khz-100khz) especially choosing gate driver is a big problem for me because as far as I know how fast (high frequency) I modulate the input signal I get better THD results (first of all Am I wrong?). I searched for high switching frequency fet driver (more than 4MHz) but I couldnt find a reliable one and decided to ask forum if anybody have a suggestion about this?
also If anybody has or know a document-application note etc.. about "class d amplifiers and underwater transducer applications", because people worked on transducer knows, it is an interesting load and usually you need to modify classical designs.
another question in a design like this, is it possible to use feedback to improve linearity, being realistic as a beginner do you think I can design a class d amplifier with feedback. and if you have a application note or document about feedback design please dont hesitate to give the links
thanks
Old 9th February 2011, 04:08 PM   #2
darkfenriz is offline darkfenriz  Poland
darkfenriz's Avatar
Give us more data: power, transducer load, acceptable ripple, wheather you need full power at full bandwidth, etc.
Concerning switching frequency, the distortion actually increaes with frequency before applying feedback. The slope of distortion increase is around 6dB by octave, the feedback can reduce the overal distorion by 6 or more dB per an octave of frequency increase, depending on how fancy feedback scheme you want to use. So distortion to switching frequency dependacy is not vey straightforward and much topology dependant.
If I were in your shoes I'd go for around 1MHz switching frequency with standard "fast" mosfets and drivers.
Old 9th February 2011, 05:14 PM   #3
ssanmor is offline ssanmor  Spain
We have experiences with customers using our BP4078 modules for submarine transducers, drop us an e-mail for more information (info@coldamp.com)
Old 9th February 2011, 06:53 PM   #4
wakibaki is offline wakibaki  United Kingdom
Banned
This looks like a good place to start:- Amazon.com: Introduction to the Theory and Design of Sonar Transducers (9780932146229): Oscar Bryan Wilson: Books.
If I was building a sonar I'd get my employer to buy me this book.
w
Old 9th February 2011, 08:34 PM   #5
hi,
thanks for the answer.
I tried a simple LTSpice simulation to see if the THD increase or decrease with increasing modulation frequency. the result shows as modulation frequency increases THD decrease. I used pulse wave genarators to drive mosfets in the simulation may be this creates difference.
and specs of the design are like this:
-2 channel X 25W
-0.01 THD
-better than %90 efficiency
-full bridge topology
-the power changes through the bandwidth because transducer has a piezoelectric characteristics so it doesnt need full load at every time thorugh the band.
you suggest t start with standart fets and drivers. what about the feedback issue is it possible to use feedback with full bridge or is it needed?
thanks again also any documents and notes is more than appreciated.
Old 10th February 2011, 05:26 AM   #6
authlxl is offline authlxl  China
SINEWAVE ELECTRONICS CO.,LTD
class d for underwater transducer Send a message via MSN to authlxl
oh!we have some type of amp for sonar ,it can works well at 3KHz-30Khz,we are now develop new type for 100Khz series,our sonar amp have used in military project,of course some more problems need to resolve,like deminsions and stablity,100W /300W/500W with transformer have produced,out voltage about 200-600V,we suggest it works at narrow band mode,if you use full range signal the output will undulations.
Old 10th February 2011, 06:19 AM   #7
phase_accurate is offline phase_accurate
Within your specs you forgot one important value: The load impedance.
If those whimpy 25 watts had to be delivered into 8 Ohms for instance you could use fast and beefy MOSFET drivers (like some types from IXYS) for your output bridge. If OTOH you need 100 V RMS in order to achieve 25 Watts things don't look that nice anymore.
Charles
Old 10th February 2011, 08:42 AM   #8
Make clear,one underwatertransducer impedance characters curve necessary indeed.
Old 10th February 2011, 04:34 PM   #9
Default underwater transducer
as you know piezo transducers have a admitance (impedance) changing through a frequency band, I uploaded the susceptance vs frequency and conductance vs frequency graphs to make load characteristics of the power amplifier clear. I extract a lumped model of the transducer to use in simulations (also uploaded it.) I'll drive the load by using a transformer (I need high voltage as you see from the lumped model transducer have big impedance).
to phase accurate: I use transformer after the amplifier to get high voltage levels.
to authlxl: the project you worked on I think merely the same if you share your experiences and if you have vital documents about this design I'll be so glad.
thanks everybody for your interest. I hope I made it more clear.
Old 11th February 2011, 04:32 AM   #10
one type underwatertransducer impedance characters curve:
class d for underwater transducerHide this!Advertise here!
resonant frequency of water (distilled) and how to make speaker play underwater Audiophilenoob Multi-Way 172 29th November 2012 02:37 AM
newbie: Piezo as Underwater Contact Mic, Z-Diode? todoke Instruments and Amps 0 28th February 2010 11:20 PM
Class D driven active Transducer Happyface Class D 2 22nd March 2009 03:09 PM
Manger transducer Bgt Planars & Exotics 1 31st October 2006 07:49 PM
Transducer nestor Parts 1 23rd October 2004 03:49 AM
Copyright ©1999-2017 diyAudio
