Go Back   Home > Forums > Amplifiers > Class D
Old 6th February 2011, 10:55 PM   #1
Default soundstream TRX1000D need parts
Hi im a technician needing advice from a engineer I'm working on this amp which mosfet transistors are fried and can't get the original part and need a suitable replacement for it. The original part number is IRF746N and there isn't any available. I think IRF740 might work as a replacement but there is no data sheet on the original part.
Old 6th February 2011, 11:33 PM   #2
Send a message via Yahoo to Th3 uN1Qu3
Remove all the original output mosfets from the board, apply power, and check the rail voltages. The IRF740 is a good mosfet but it may not be optimal for your amplifier. I see it's rated for 500W on 4 ohms and it appears to be a full bridge, at least that's what i can make out of the marketing blurb. In that case the rail voltage will be around 140 volts or +/-70v if it's a half bridge. It is also rated for 1 ohm operation which means you have a worst case current of 32 amps for the rated 1kW. That takes a lotta mosfets!
"Audio grade" components simply means that they failed at a more critical job.
Old 7th February 2011, 09:13 PM   #3
pergo is offline pergo  Italy
power supply mosfets are IRFZ46N
Maybe you read 7 instead of Z.
http://www.irf.com/product-info/data...ta/irfz46n.pdf
SoundStream 404 SS64 Car Audio 2 11th October 2008 12:51 AM
Soundstream shaolinfox30 Car Audio 1 24th July 2007 09:03 AM
soundstream 6.0 ben04srt Car Audio 10 11th March 2007 04:56 AM
Soundstream? thylantyr Pass Labs 6 10th November 2006 08:35 PM
PARTS PARTS PARTS!!! Infocus Powerview 820, triplet, ballast, light, power supply!!! marioinla Swap Meet 1 31st August 2004 04:22 PM
Page generated in 0.09440 seconds (64.47% PHP - 35.53% MySQL) with 10 queries
