Ringing on class d output inductor.
Old 6th February 2011, 12:46 AM   #1
nigelwright7557 is online now nigelwright7557  United Kingdom
nigelwright7557's Avatar
Default Ringing on class d output inductor.
I am getting around 35 volts overshoot then ringing on my class d output inductor.
Is there any way to reduce this ?
PCBCAD51 pcb design software. 2018 version out now. http://www.murtonpikesystems.co.uk
Old 6th February 2011, 07:50 AM   #2
luka is offline luka  Slovenia
luka's Avatar
is this after inductor?
could be that core is saturated.
was this with any input signal?
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Old 6th February 2011, 02:25 PM   #3
This is before the inductor.
I am using a 16 amp indcutor so it shouldnt be saturating.
The power supply is only a 2 amp supply.
This was without an input signal.
Old 6th February 2011, 03:28 PM   #4
luka's Avatar
peak current comes from caps, 2a is a lot from that point of view. can you post after inductor, am thinking cross-conduction could be going on, or bad layout/inductive elements, if you have any resistors before fets(i don't think so)
I FEEL SLOVENIA
Old 6th February 2011, 03:50 PM   #5
There is a 470nf capacitor after the inductor.
Deadtime is 125nS, I tried 25ns but it made no difference to the problem.
The mosfet gates have a 10R before them.
I put two inductors in series just to try it and there is a slight improvement.
I have ordered a 28 amp inductor to see if that helps.
The inductor gets very hot around 120 degree C.
Old 6th February 2011, 04:44 PM   #6
luka's Avatar
really, that hot?
i cant say that inductor is saturating, but it is a possibility
could be that it is wrong material
what is the inductance? and switching freq?
load connected?
I FEEL SLOVENIA
Old 6th February 2011, 04:54 PM   #7
AP2 is offline AP2  Italy
Banned
Please...change material of toroid.
Old 6th February 2011, 04:54 PM   #8
really, that hot?
load connected?
It is a toroid 22uh and 16amps.
Odd thing is my supply is just a bench supply that gives out 2 amps so I cant see why any overcurrent is being triggered unless it is drawing very narrow pulses from the smoothing capacitors.
Old 6th February 2011, 04:57 PM   #9
I am currently using this toroid.
BOURNS JW MILLER|2305-V-RC|TOROIDAL INDUCTOR | Farnell United Kingdom
Old 6th February 2011, 05:01 PM   #10
luka's Avatar
correct, i drive 350w on output, yet i have 130w max supply, most of the power comes from caps
what material did you use
I FEEL SLOVENIA
Ringing on class d output inductor.Hide this!Advertise here!
Source for output air cor output inductor?? sam9 Solid State 12 2nd July 2015 08:44 AM
Design of output inductor for class D amplifier zilog Class D 155 26th December 2006 08:10 AM
Copyright ©1999-2017 diyAudio
