| Class D Switching Power Amplifiers and Power D/A conversion |
I am building a small, simple, inexpensive amp for a 2.1 system. I'm using a TA2020 board from ebay seller HLLY WiFi (like ebay item #400073068762)
driving a set of Mirage OMD5 speakers. My question is: is there an elegant way to tap the signal so I have a signal out for a subwoofer? Due to room and spouse constraints I don't really want to run speaker wires to the sub's speaker-level inputs and then back to the amp. The OMDs are right on the efficiency line so I fear that simply splitting the signal to a separate set of RCAs will hurt quality too much. I've been considering building a matching pre-amp with Helder's tube board, if that will help me out at all. |
#2 |
Splitting the RCAs won't be a problem. The amps have enough gain to make up for it.
"Audio grade" components simply means that they failed at a more critical job. |
#3 |
You can connect the amp's out to both the speakers and the sub. You get to use the amp's volume control too.
But I think that'd hurt quality more than splitting RCA. The subwoofer does not have RCA outs? Last edited by wwenze; 1st February 2011 at 05:10 AM. |
#4 | ||
I haven't decided on which sub I'm getting yet but I've been looking at some that do not have RCA pass-through. My ideal solution would be if I could isolate a mono, variable level, line out for the sub so I could run one single cable to it. The run to the sub will be about 2.5m long. |
| trouble matching line level to guitar amp input level...any help? | mondogenerator | Tubes / Valves | 5 | 19th December 2009 10:00 AM |
| Line level subwoofer out voltage? | thefish | Subwoofers | 2 | 3rd February 2007 07:29 PM |
| lesser of two evils, high level -> line level, digital volume control | mazurek | Solid State | 3 | 19th November 2006 12:25 AM |
| Tapping a balanced connection | TheoM | Parts | 1 | 29th October 2004 02:51 AM |
| Cat 6 STP as subwoofer line level cable | creek | Everything Else | 6 | 24th October 2004 07:50 PM |
| Page generated in 0.08845 seconds (73.80% PHP - 26.20% MySQL) with 10 queries |
