| Class D Switching Power Amplifiers and Power D/A conversion |
I apologise in advance if this is a dumb question:
I have a balanced MiniDSP board feeding an icepower 1000asp module...well a set of each actually (monoblocks) I would like to have a switch on the back of each amp that can change the input to accept balanced or unbalanced inputs. The first Bit seems easy enough.. for the input to the MiniDSP board I can just have a SPST switch shorting the Neg to GND... However to get an unbalanced output from the MiniDSP board it requires the same shorting of Neg to GND and the same again for the input to the Icepower module...these obviously can't all share the same switch I assume.. Now my simple brain can only think of three switches and a lot of wires but I know there is obviously a much simpler way of achieving this but incapable of figuring it out. Balanced output is not needed from the Icepower module. To summarise.. MiniDSP Input - Balanced/Unbalanced MiniDSP Output - Balanced/Unbalanced 1000ASP Input - Balanced/Unbalanced 1000ASP Output - Unbalanced Like I say - sorry for a dumb question, I am just nowhere near experienced as most here. Thanks Last edited by Aurality; 21st January 2011 at 06:51 PM. |
#2 |
If I'm visualizing this correctly, a single DPST (double pole, single throw) switch should work.
Use one pole to short the (-)input of the MiniDSP to ground, and the other pole to simultanously short to ground the (-)output of the MiniDSP and the (-)input of the 1000ASP.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja |
#3 |
A DPDT switch is used in this diagram only because the software didn't have a DPST. In reality you can use either one.
#4 |
Excellent! thanks very much for that mate. much appreciated, Looks like it should do the
job nicely
| balanced to unbalanced and back | FastEddy | Parts | 0 | 5th September 2007 10:29 PM |
| Unbalanced to Balanced | mcash257 | Parts | 3 | 14th October 2004 12:03 AM |
| unbalanced/balanced/unbalanced conversion using transformers | vladimir | Solid State | 10 | 27th February 2003 06:54 PM |
| unbalanced or balanced | theturtle | Everything Else | 4 | 5th January 2003 04:52 PM |
| Zen Balanced Line Stage Balanced vs Unbalanced | macka | Pass Labs | 28 | 11th December 2002 06:18 AM |
| Page generated in 0.07430 seconds (69.23% PHP - 30.77% MySQL) with 11 queries |
