| Class D Switching Power Amplifiers and Power D/A conversion |
I am using a UCD400HxR to drive my Altec horn speaker which is very efficient around 100db. The problem with the sound is that it sound too fast hardly any extension. The bass seem to pull back very not extended, the vocal appear to rush through the singing. Is there anything I could mod on the amp to reduce the speed? I hope to make it sound like a tube amp. Thank you for your kind advise. Tong |
#2 |
I would be happy to swap the UCD400 for my Diyparadise TA2020 (15W). Ha Ha
Regards. Michael |
#3 | |
#4 |
Thank for the advise. I will try it out. Sometime back I tried installing a speaker auto transformer at the amp output to step up the voltage from "8 Ohm" to "16 Ohm" and yes the music sound slower, bass is more extended, but unfortunately, there is a loud hissing sound. The hissing sound changes when I touches the speaker binding post. I did read some where from some one suggesting that high efficiency speaker don't match well with high power amp as the speaker driver will move too fast hence no chance to drive the music out the way it should. |
| f/s hypex ucd400 hg with onboard hxr regs | slr 5000 | Swap Meet | 8 | 17th March 2009 10:26 AM |
| high efficiency speaker with a budget of us$1000,00 | angeloitacare | Multi-Way | 21 | 22nd May 2008 11:23 PM |
| Large high efficiency WMTMW speaker project | Brett | Multi-Way | 9 | 1st August 2007 06:19 AM |
| High Efficiency Speaker Plans | BillFitzmaurice | Swap Meet | 6 | 25th September 2004 10:12 PM |
| Page generated in 0.08502 seconds (73.39% PHP - 26.61% MySQL) with 10 queries |
