problem with T-amp
problem with T-amp
Old 9th January 2011, 12:54 PM   #1
formula11 is offline formula11  United States
Default problem with T-amp
Heres the problem Im using a Muse M21 It works fine when I have a MP3 player hooked up to it.But yesterday I tried to hook it up to my direct TV cable box And it seems to trip the chip. If I wait awhile then hook up the MP3 it will play plug the RCAs back to the cable box nothing?
Old 13th January 2011, 02:17 AM   #2
kheper is offline kheper  United States
kheper's Avatar
Sounds like a protection circuit in the amp or in the power supply is kicking in. If you are using a laptop charger as the supply, check the green led for operation.
Your cable box should put out a line level signal. Some have adjustable volume levels. Turn the Muse to minimal volume on the front pot, and (if available) set the cable box to put out a low volume before sending a signal to the Muse.
Old 14th January 2011, 08:13 AM   #3
thanks Ill try it
Old 15th January 2011, 12:46 AM   #4
kheper's Avatar
I do not know about the Muse, but the Sure amps I bought have an input sensitivity selector. The most sensitive setting clips the amp hard and very easily with any source. Check your Muse manual for such a switch.
problem with T-ampHide this!Advertise here!
Help!The display problem on Marantz CD94&CD95. kclai Digital Source 14 24th July 2010 10:17 AM
T-Amp and Pre Amp shared power problem tedlevit Class D 3 26th February 2008 02:22 PM
Mosfet amp problem, Slone amp 5th element Solid State 14 22nd March 2004 11:03 PM
