Go Back   Home > Forums > Amplifiers > Class D
Old 9th January 2011, 04:52 AM   #1
Send a message via MSN to ArjenShenzhen
Default Miniature Class-D modules
Dear friends,
Many of us enjoy audio outside the house, and build our own portable speakers, for witch class-D as we know is useful because its low battery consumption and high sound quality.
Green and eco friendly is also an issue these days, so i've been thinking what i can do to make the world a little greener, and i've come up with a miniature amp board that has been designed to be used with solar power or (lithium) battery power, with very minimal current consumption.
its a small unit with 2 class-D mono amp IC's and a battery indicator it measures just 5X3.5 CM and is just 1Cm in height, but performs admirably in combination with some nice 2/3/4 inch full range drivers.
i've made some finished speakers of witch ill show some photo's as well.
I hope to get some comments on my own designs, and some new idea's, and that other DIY'ers will post there mini creations.
Click the image to open in full size.Click the image to open in full size.
Always check the power supply... and my spelling...
Old 9th January 2011, 04:58 AM   #2
katana2112's Avatar
Going to sell the amps/boards?
Aggressively Passive
Old 9th January 2011, 06:19 AM   #3
if there is demand, ill produce, this is easy to make for me.
Postings here are more for seeing what other ideas there are, especially in combination with solar im interested what others have done before.
Greetings,
Arjen Helder
Old 9th January 2011, 09:46 AM   #4
hi, what is the idle power consumption? :-)
Old 9th January 2011, 01:22 PM   #5
hi there, its 10mA Idle, 13mA with the battery indicator ( at full batt, so 4 burning Led's )
Old 9th January 2011, 02:17 PM   #6
Saturnus's Avatar
Why not save 25% of idle consumption and use one tri-colour LED for battery status?
Old 9th January 2011, 03:06 PM   #7
Hi there,
Because its soo little, just 3mA for 4 leds, and its separately connected, so an extra pushbutton could also be used to check the batt status, and if i solder the SMD LED's the current is even lower, something like 1.8mA when the amp is producing sound the current is around 100mA for normal sound levels, maybe 200mA ( average, not peak consumption ) at higher levels, so then the batt indication is just 2~4% of the energy consumption, plus that this IC cannot be used to drive just one LED, its a rather simple IC.
Old 9th January 2011, 04:08 PM   #8
Saturnus's Avatar
Btw, passing these of as your designs is not entirely true is it?
They are the design of V-bro from the www.41hz.com forum.
More exactly they're copies of these designs:
http://www.41hz.com/forums/content.p...MP-11-Megamini
http://www.41hz.com/forums/content.p...amp-32-bicycle
Old 9th January 2011, 04:49 PM   #9
kc7wdg is offline kc7wdg  United States
Not the first time he has done something like that. He tried to advertise his board in hifimediy's tk2050 thread. Copying is fine but give credit.
Old 9th January 2011, 06:07 PM   #10
v-bro is offline v-bro  Netherlands
v-bro's Avatar
I'm pretty sure that PVC tube speaker can't measure up to my Macaroni, neither will the aluminium box be able to. It'll just turn pale in a shoot out test...
And indeed, I designed these years ago.
Funny man you are Arjen, you do have some pretty nice class D board designs, although I doubt now about what is your own and what not. I recall a TA3020 thread too which you started and presented a board as your own design some time ago, untill some other guy came by which turned out to be the actual designer....
Indeed nobody minds if you copy a design as long as you at least refer to the original. Better well copied than designed poorly, I agree...
Max. cone displacement can be several foot on any speaker!Too bad it can be done only once......
Class D Modules Ricky Vendor's Bazaar 7 2nd December 2008 08:56 AM
ESP class A modules 56oval Solid State 0 28th January 2008 09:19 AM
Class D Modules Ricky Vendor's Bazaar 1 9th April 2007 08:31 PM
Page generated in 0.10792 seconds (76.95% PHP - 23.05% MySQL) with 10 queries
