Go Back   Home > Forums > Amplifiers > Class D
Old 4th January 2011, 01:45 AM   #1
Default Help with Helder TK2050 board
I recently received 4 TK2050 boards from Arjen Helder. First impressions were very positive. After only about 10 hours of use, one has no output. The 7805 regulator gets very hot immediately. I will pick up another regulator tomorrow to see if it helps. Does anyone have experience with a similar issue. Is the amp history?
thanks
Old 4th January 2011, 03:13 PM   #2
julcat is offline julcat  Mexico
I have 4 TK2050 boards from arjen and they all work without any problems, in general Arjen's products have good reputation of quality and sound.
Old 8th January 2011, 03:04 AM   #3
Homl is offline Homl  Canada
Have you double check for DC offset at the output?
One of my boards had a significant amount of DC offset. I just turn the little blue pot to set it back close to zero.
Old 9th January 2011, 04:27 AM   #4
Send a message via MSN to ArjenShenzhen
Hi there, Mixed mechanic,
Have you contacted me already for this problem ?
Ill help you out of course. i've noticed that some of the board of the previous lots have some fall-out issues, so of course your problems fall within the usual warranty.
Greetings!
Arjen Helder
Always check the power supply... and my spelling...
helder mk3 ta2024 pharoahra Class D 32 Yesterday 12:12 AM
New TK2050 board hifimediy Class D 2094 10th May 2012 12:36 AM
Sure electronics 4*100 watt @ 4ohm, TK2050 D-class Audio Amplifier Board aquapiranha Class D 3 30th May 2011 11:06 PM
Where is Arjen Helder steveww Class D 6 5th October 2010 06:32 PM
Best sounding board ~60W/8ohm TK2050/TAS5613/ ? Galgo Class D 5 3rd June 2010 07:34 AM
Page generated in 0.07079 seconds (71.67% PHP - 28.33% MySQL) with 10 queries
