| Class D Switching Power Amplifiers and Power D/A conversion |
I am almost finished wiring my Hypex UCD400 monos in a single chassis. According to the rep at Hypex, the yellow leads coming out of the transformers are not used.
Could someone please tell me what is the proper way to dress these unused leads on the TR501A transformers? Thanks in advance. Slowlearner |
#2 |
Cut off the copper ends and heatshrink some tubing over the wire ends.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#3 |
Why aren't the yellow leads used?
#4 |
Could be for different mains settings i.e. USA UK
#5 |
No no; I checked the wiring schematic. The yellow leads are secondary windings.
#6 |
I checked once more the TR501A; the yellow pair is 12V secondary.
If not necessary for the amp Nigel's advice in #2 is correct. |
#7 |
How close do I cut the leads off to the transformer body?
#8 |
You don't have to cut them off at all. He meant to cut off any exposed copper at the end of the wire and then put some shrink tube over the end.
"If you don't like funerals don't kick sand in Ninja's face." - Ninja |
| Transformer question | shon35us | Chip Amps | 18 | 19th February 2009 05:20 AM |
| Question about transformer | goldkenn | Chip Amps | 3 | 11th November 2008 05:45 AM |
| transformer question | abiedoodles | Parts | 3 | 10th February 2008 11:35 AM |
| transformer question | enochRoot | Tubes / Valves | 1 | 5th September 2005 02:36 AM |
| transformer question | xcortes | Chip Amps | 0 | 31st October 2004 05:04 AM |
| Page generated in 0.09091 seconds (75.29% PHP - 24.71% MySQL) with 10 queries |
