My discrete class d project My discrete class d project - diyAudio
Old 7th November 2010, 01:51 AM   #1
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Default My discrete class d project
Just started on a new project, a class d discrete approach.
Uses triangle wave generator, comparator, xor phase splitter and irs2113 hi/lo side switch.
Still in the testing stage.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk
Old 7th November 2010, 01:54 AM   #2
1
Old 7th November 2010, 11:38 PM   #3
Circit diagram.
A bit small due to screen capture.
Old 9th November 2010, 11:03 PM   #4
Still testing.
Got the square wave and ramp working cleanly by adjusting components.
Designed improved level translator from output of comparator to xor gates.
This works cleanly now.
At this point it outputs sound althogh with a little more noise than i would like.
Found tweaking the DC offset improved the noise situation.
Output MOSFETs were getting warm so changed gate resistors from 10R to to 56R now they stay cold.
Old 9th November 2010, 11:22 PM   #5
savu is offline savu  Romania
savu's Avatar
Send a message via MSN to savu Send a message via Yahoo to savu
can you provide a readable schematic?
regards,
savu
1'st rule of chess:
The only way to get smarter is by playing a smarter opponent.
Old 9th November 2010, 11:31 PM   #6
regards,
savu
Thats the best i can do without chopping it up into quarters and then it would be meaning less.
My earlier message explains all the stages.
Ramp generator and audio input, comparator, xor phase splitter, hi/lo side switch into irfb4019 mosfets.
Its pretty basic really. Sadly takes more components than a 2092 circuit but what components it uses are very cheap. The inductor is the most expensive part then the 2-50 IRS2113.
Old 10th November 2010, 03:34 AM   #7
savu's Avatar
Here is a similar project with discrete parts,
+/-45Vdc supply, 150W RMS into 4 ohm, 250khz, 0.31% THD @ max power, 1.6W dissipated per Mos Fet.
It only exists in LTspice, I never built it.
savu
1'st rule of chess:
Old 11th November 2010, 05:27 PM   #8
Th3 uN1Qu3 is offline Th3 uN1Qu3  Romania
Send a message via Yahoo to Th3 uN1Qu3
Well then would you mind if i build it? However i'll use higher supply rails and two pairs of MOSFETs, i need 200-300W on 8 ohms.
"Audio grade" components simply means that they failed at a more critical job.
Old 11th November 2010, 05:49 PM   #9
savu's Avatar
I wouldn't mind.
tell me the exact configuration and the parts that you intend to use in order to redesign it for you're specific needs.
regards,
savu
1'st rule of chess:
Old 11th November 2010, 06:04 PM   #10
I'll have to examine the schematic more thoroughly - i'll do so in the weekend.
My discrete class d projectHide this!Advertise here!
My all discrete prefilter class-D kartino Class D 10 7th August 2006 08:47 AM
My 13x discrete class-D kartino Class D 6 21st November 2005 07:44 AM
recommend discrete Class D rellik Class D 11 3rd November 2005 01:27 AM
How much innovation is possible with Discrete Class-A Amplifiers? dgardner Solid State 20 12th August 2005 01:13 PM
Copyright ©1999-2017 diyAudio
