Go Back   Home > Forums > Amplifiers > Class D
Old 13th October 2010, 03:37 PM   #1
Default Ucd for s/woofer appln
Hi friends,
I want to build a UCD with the following specs:
freq=250kHz.
s/woofer = JBL CS1215, 4 ohms, 275W max.
req amp power = 200W.
Unfortunately, i have no access to an oscillioscope . and would like to get help on the following:
1) How to calculate values L, C for output filter?
2) Is a gain of 56 problematic?
3) How to provide the GD power supply with good peak-current capability?
4) How to work out values for the resistors around the level-shift transistor?
Schematic attached.
Thanks in advance.
Old 13th October 2010, 03:56 PM   #2
m-tech is offline m-tech  Serbia
First, use some software for simulations. LTspice is free, and very good for this things.
You can find a lot of finished projects which are almost same as yours.
Old 13th October 2010, 04:43 PM   #3
savu is offline savu  Romania
savu's Avatar
Send a message via MSN to savu Send a message via Yahoo to savu
@newvirus2008
related to question 4 try this:
http://ufdemo.uni-information.com/au...evel-shift.gif
it is from here:
ucd 25 watts to 1200 watts using 2 mosfets
regards,
savu
1'st rule of chess:
The only way to get smarter is by playing a smarter opponent.
Old 14th October 2010, 10:19 AM   #4
thanks for the link savu. i think the level-shift problem is over.
Any suggestions regarding the output filter / loop gain etc.?
Old 14th October 2010, 04:43 PM   #5
Also IRF530 is rated at 100 Vdsmax. Is it advisable to apply +/- 45V into an IRF530?
Old 14th October 2010, 06:15 PM   #6
savu's Avatar
I have no clue how to calculate it.
just use LTspice
regards,
savu
1'st rule of chess:
Old 15th October 2010, 10:25 AM   #7
If this is only for sub application, why go 250kHz? 50 kHz is way enough!
reg 1) : if only one pre-defined load (woofer) is to be applied, it is relatively easy to find good LC values. In fact, this gets even more easy as the factor between your LF bandwith (assuming <=200Hz) and your fs is sooo big.
Old 15th October 2010, 10:28 AM   #8
savu's Avatar
Yes but let's presume that you will want to use the sub woofer to listen to dubstep or drum and bas. you will need that extra sw freq ... 250Khz is easily achieved, so i do not see a problem there.
regards,
savu
1'st rule of chess:
Old 15th October 2010, 02:04 PM   #9
Yes savu, I want it to be around 250kHz!
I will be initially testing it with full range audio and ordinary speaker, so i want it to be 250kHz. I mentioned 's/w' so that the target distortion levels are clearly understood.
thank you Vienna tom, but would you please share your idea on getting LC values for the filter?
Old 15th October 2010, 03:33 PM   #10
Do you think you need some special LC filter because it's going to be subamp ? No, you are wrong. Use 30uH and 680nF. These values are used typically ( at least in diy ).
If you want to use it as subwoofer amp, then you need active low pass filter on the input side. Btw.
Lout = Rsp / (2 x Pi x Frolloff), Pi=3.14
Cout = Lout / (4 x Rsp x Rsp x K x K ), K=0.707 typically value.
WTB: 6.5" woofer to replace broken woofer in cheap band pass subwoofer Jimmy154 Swap Meet 2 5th October 2010 02:00 PM
Woofer replacement for Infinity Reference 2000.5 Woofer kchilaka Multi-Way 0 28th September 2010 05:11 AM
UcD 180 or UcD 400 with +/- 48VDC supply Ray Weikel Class D 17 7th March 2009 06:11 AM
looking to upgrade 8 ucd 180st to ucd 180hg mazurek Swap Meet 6 31st May 2007 12:47 PM
Qts of Push-pull woofer and Compound Woofer System... haggy Multi-Way 1 13th December 2001 01:30 AM
Page generated in 0.10721 seconds (76.15% PHP - 23.85% MySQL) with 11 queries
