Go Back   Home > Forums > Amplifiers > Class D
Old 27th September 2010, 06:54 AM   #1
JJwzhao is offline JJwzhao  China
Default possibility of signal lossing
there is always a question in my mind, i have nothing, i can't do some testing to overturn that question that problem.
for Class-D amp, if there are 2 signals (with different frequency and different levels and combined) inputs, what happens at the outputs, after the LPF, can we still see that 2 whole signals.
or what happens after the comparators.
compare the signal level within the input signal and the triangle wave, if there are 2 signals inputs, and both of them the level is high than the triangle, so, the one signal will be ignored, is it right.
maybe it is a stupid question, looking for the answer.
Old 27th September 2010, 08:26 AM   #2
Pafi is offline Pafi  Hungary
The question is underspecified. (Partly because of poor english.) Where do the signals go? Normally an amplifier has only 1 input. Do you mean the sum of these signals goes into the amplifier? (Or what? There are several other possibilities!)
The signal level mustn't exceed the triangle, otherwise the output will be distorted, even if there is only 1 modulating signal. This acts as a simple (hard) limiter.
No.
Old 27th September 2010, 09:25 AM   #3
AP2 is offline AP2  Italy
I support your theory, this is a very unusual and new.
will not be easy to get support from others.
two signals can be applied to a comparator, is a triangle wave, the other can be the result of the filter (integration) which is summed with the modulation.
The output (modulation + integration (Adj-phase is necessary)) contains information to clean up the process.
Only two words are certainly not clear, but I can not say more.
just to give you comfort in your idea.
Old 28th September 2010, 07:48 AM   #4
sorry for my poor english, yes, i mean the sum of these signals.
it is my mistake on my question, it should be lower than the triangle wave.
No.
this picture can show where is my question on.
red line: signal 1
blue line: signal 2
black line: triangle wave for compare.
so, what will be happen on the part of the red line in the yellow area?
will this signal be lost?
Old 28th September 2010, 10:48 AM   #5
Is not lost because the red modulates the blue one. (Really do not see two separate signals) but a modulated signal on the other. This affects the result of the comparator.
Old 28th September 2010, 11:49 AM   #6
It is a little dangerous to say one input signal modulates the other one. The term modulation is normally used when one signal is used to influence the other (like control its amplitude, phase or frequency).
The "payload" that is going to the modulator is actually the SUM of both input signals (which in this case haere would be high enough to overmodulate BTW). This is also called linear superposition.
There is however some modulation (i.e. mutual influence like IMD) going on in practice due to circuit non-idealities, but this is a separate chapter.
Charles
Old 28th September 2010, 01:26 PM   #7
red line: signal 1
blue line: signal 2
You can't expect such a small fraction of the signal to pass through individually on a sampled system! Your question basically refers to the sampling theory, however in this case the sampling intervals are not uniform. Between two sampling points the datails of the original signal are "lost", but if it was appropriately band-limited, these points can be restored (by a filter) from the other time-points. In case of uniform sampling the bandwidth should be less then half as the sampling frequency to achieve perfect restoration (Shannon-theorem), in case of PWM ("natural sampling"), the restoration always have some error, the higher the fsw/fsignal ratio, the lower the error.
An other question is signal level: the sum of the signals should not exceed the triangle amplitude.
If signal amplitude is OK, and freq of every components are lower then 1/5th...1/20th of the triangle, then the original signal can be restored, but you won't see it in a small time window. (1/5: acceptable, 1/20: almost perfect)
One more thing: one modulating signal (wich can be the sum of two sine wave) goes into the modulator, one PWM signal comes out, and one signal can be restored, the original sine waves cannot be seprated (unless the receiving side knows what was transmitted).
Summary: PWM is approximately a quasy-linear operation, if we assure the neccessary conditions.
Old 28th September 2010, 01:55 PM   #8
Charles
I answered the question: "lose red signal?"
do not lose anything. is a different matter if the effect of the modulator (comparator with a triangular signal on pin) in this case, the PWM output will have both the segnali.eg: the pulse width modulation will have 100Hz and at the same time will change width of pulse to frequency of the second signal eg. 20Hz).
Of course there are the proportions for the two signals. amplitude and time domain.
Also,addition or subtraction produces the same result for intermodulation.
Difference is only in reference to a third signal.
Old 29th September 2010, 12:14 AM   #9
I agree with you, "the PWM output will have both the signal", although i unable to do some testing to verify, logically, it can be.
but, the another issue is the FET in class-d amp normally working at the switch status, how can FET differentiate those 2 PWM.
and also, the LPF behind the FET, how can it works.
thanks
Old 29th September 2010, 07:35 AM   #10
thanks
Sorry for very simple pic .
Concept is clare, in this case two modulation is present at output di class D amplifier (100hZ & 20hZ).
My previous post refers to the same concept but using
high frequencies (near to carrier). to obtain the fix of the band and at the same time neutralize the artifacts of the conversion. This is the new concept on which the modulator MXD. is totally new and a bit complex to manage the phase signal (this changes with the modulation).
Someone on the thread "DXA-400 amplifier" said I probably copied ....
Just measure the pin of the comparator to see that there are two signals at carrier frequency.
Possibility of Tube substitution trough MOSFETs tiefbassuebertr Tubes / Valves 20 31st July 2009 12:14 PM
ETF07 - Last possibility to join emilesprenger Tubes / Valves 1 25th November 2007 04:23 PM
Possibility query: MyRef + Tube? eVITAERC Chip Amps 31 2nd July 2007 01:57 PM
Possibility of parts buy? rosss Pass Labs 5 22nd January 2003 02:14 PM
Page generated in 0.13995 seconds (84.87% PHP - 15.13% MySQL) with 11 queries
