helder mk3 ta2024 - Page 3 - diyAudio
Go Back   Home > Forums > Amplifiers > Class D
Old 24th April 2011, 07:36 PM   #21
his preamp only has a single input,but does have a volume pot.
there go look at it.
NEW tube pre-amp MKIII 12AU7 fully assembled | eBay
Old 24th April 2011, 08:51 PM   #22
Originally Posted by GJF View Post
All finished and cased.
Changes to standard board are bigger (18,000uf) tank cap and Panasonic FC's (220uf, 25v) at the chip, a 3.3uf cap added to the 5 volt reg line and of course the two flipping huge Oblligatto 2uf coupling caps!
Sound is a lot smoother and detailed with little listener fatigue.
Still don't think it's as good as my Amp-32 but it's pretty good for the money.
Case was 1 of a pair bought off that site second-hand, hence the spare holes!
13 volt sm power supply.
are these the caps you are using?
Obbligato Film Oil Capacitors
Old 25th April 2011, 03:59 PM   #23
GJF is offline GJF  United Kingdom
Yep, they're the ones and after a long burn in time they really do make this little amp sound rather good.
So good in fact that it has become my amp of choice for everyday listening.
Old 25th April 2011, 07:57 PM   #24
cool i may try a set.i was honestly expecting them to be expensive,but after seeing what they cost.i think im going to order a set soon.
Old 13th August 2011, 09:56 PM   #25
i just added some power supply caps to mine.they are elna 6800uf x 2.that has made a decent difference to the overall sound of the amp.ive still yet to try different input coupling caps.i think that will be my next and final mod to this.if i do anything else i will start from scratch with something a bit more powerful.adding 13,600uf power supply capacitance has definetly made the sound stage larger.it has made a bit of a difference in the bass region as well.
Old 14th August 2011, 12:33 PM   #26
gychang is offline gychang  United States
I have several amps from Helder (all sound good, even the cheapest model to my ear, after prolonged daily use MKIII may have a slight edge) and I am somewhat confused with the title of this thread. Only MKIII I am aware is with TA2020 chip, not with TA2024. Are we discussing MKII with TA2020 as pictured here?
MKll Version Tripath TA2020 PCB 25w CLass-T amplifier | eBay
Good sound from Davis, CA
Old 14th August 2011, 04:48 PM   #27
the title of this thread is what is being discussed mk3 ta 2024.the top of page 2 of this thread has some pictures of it.
Old 7th October 2011, 08:04 PM   #28
look here MKIII TA2024 amplifier module :: .
Old 20th May 2012, 02:04 AM   #29
with the addition of some nice speakers.i can say i hear details ive not previously heard.this amp was decent on some bookshelf speakers i had.but im listening now to some infinity rs-6 kappa.the amp truly shows its potential with these speakers wow.i would have never believed one of these t-amps could produce this kind of bass.the old setup had nice bass with a subwoofer.i can hear this things true potential now,and its even better than i originally thought.
Old 20th May 2012, 08:19 PM   #30
pkozul is offline pkozul  Australia
Same here. I've also got a pair of Infinity speakers, although they are RS2 model (bookshelf). I've tried the TA2024 with several different sets of speakers and so far the Infinitys have been the best match. Excellent detail and plenty of low end.
Recently, I tried out one of those Indeed G2 tube preamps, and that ended up giving a warmer, smoother sound, which I enjoy even more.
Pete
Helder MKII TA2020 Amp PSU Wiring Obe1 Class D 10 22nd January 2014 01:33 PM
Arjen Helder Buffer V2 Zero One Class D 72 19th May 2013 12:45 AM
Good Experience with Arjen Helder mfong Class D 6 10th May 2011 07:07 PM
Arjen's helder TA2020 MKiii went fault :( chchyong89 Class D 13 17th September 2010 10:24 PM
Why triode Mk3 is louder than stock Mk3 Wieslaw Lipowsk Tubes / Valves 5 14th June 2007 01:18 PM
Copyright 1999-2017 diyAudio
