Giving class D a try
Old 8th September 2010, 08:20 AM   #11
AP2 is offline AP2  Italy
Banned
Originally Posted by Sch3mat1c View Post
Why?
It makes placing SMTs much easier.
Tim
You did a good layout of the components, I understand that you did not cover (color solder) so as not to oxidize the copper, in this case you can use transparent color spray to protect (only has 2 pF / cm).
tin has a high electrical resistance (very poor conductor) compared to copper, it is known that electrons propagate in the surface of the conductor (not in).
Old 8th September 2010, 03:37 PM   #12
Sch3mat1c is offline Sch3mat1c  United States
Sch3mat1c's Avatar
Send a message via ICQ to Sch3mat1c Send a message via AIM to Sch3mat1c
Ah, but the surface that's carrying the most current is the *inside* surface, because the same current (give or take) appears as an image on the ground plane, on its inside surface as well. For a 2oz board, skin effect starts taking effect above 1MHz, and the plating won't matter until 10MHz (remember, the skin depth in solder is deeper than in copper, so it is still deep enough to reach the copper anyway). Harmonics past 100MHz in this circuit carry negligible power. For that matter, I don't *want* harmonics that high, they're an EMC hazard. If tinned boards help reduce RFI, it's a good thing!
Tim
Seven Transistor Labs, LLC
Projects and Resources / Electronic Design and Consultation
Giving class D a tryHide this!Advertise here!
Is my Powersupply giving enough... Power? icecoolwas Class D 11 2nd February 2009 02:09 PM
Turntable giving out too much treble. thelostpatrol Analogue Source 2 5th April 2007 12:49 AM
Giving them the horn? JRKO Multi-Way 7 3rd July 2004 04:49 PM
not giving up on the SOZ MEGA_amp Pass Labs 3 19th May 2004 07:33 PM
