New to this -- recommend a good ~50Wpc board?
Old 18th August 2010, 06:16 PM   #1
rongon is online now rongon  United States
rongon's Avatar
Default New to this -- recommend a good ~50Wpc board?
I'm looking for a way to make an inexpensive stereo amp out of kit boards. 50 watts per channel should suffice. The intended use is as a gift to someone who plays classical music and opera CDs and FM radio into a pair of floorstanding speakers of moderate efficiency.
I'm a tube hobbyist person, so am not adept enough at solid state to build from scratch. Figured I'd get my feet wet with a kit. I'd buy the enclosures separately, along with the jacks, binding posts, etc.
I was thinking I'd put an input selector switch and volume control in there and call it an 'integrated' amp. There's no need for a tape monitor loop.
What is the typical input sensitivity of these amp kits? Would the output from an FM tuner be capable of driving one to near full power? (I figure about 250 to 500mV from the tuner, but I don't know for sure.)
How do these Class D amps sound? Are they comparable to store-bought receivers in the $500 USD range? Or (hopefully) a noticeable step up from that?
So, what are the best kits available these days? Chinese stuff from Ebay? If so, are there really good ones to get? Others in particular to avoid? Or does Parts Express have a good kit that will fill the bill?
I'm basically looking for a pleasant (non-aggravating) sounding amp for cheap.
Thanks.
Old 18th August 2010, 06:40 PM   #2
Tekko is offline Tekko
Banned
Maybe an AMP5 or AMP6 from 41hz would suffice, alittle tricky to assamble tho.
Perhaps a preassambled one from ebay like that 2x100w from connexelectronics or something.
Do some looking around and see if you find something you like.
Old 18th August 2010, 06:44 PM   #3
keantoken is offline keantoken  United States
keantoken's Avatar
Try this.
Based on Hugh Dean's AKSA 55
Ask in the thread, I believe Greg has PCB's he can offer. The AKSA is legendary as well as super simple, I think it is what you are looking for.
Or if you want to go whole hog you can purchase the original from aksaonline.com.
- keantoken
The Kmultiplier rail filter! -=- The Simple Kuartlotron Superbuffer!
Need something built, repaired or modded? PM me and ask what I can do!
Old 18th August 2010, 07:37 PM   #4
rongon's Avatar
Have done some looking around -- Is the Sure Electronics TA2050 board decent?
2*100w TK2050 TP2050 Tripath Class-T AMP Board Upgraded - eBay (item 250681462338 end time Aug-18-10 21:15:06 PDT)
I was looking at AMP4 from 41hz. Tried to log on to 41hz site, but it won't come up. Network problems maybe. I'll try later.
It looks like the AKSA boards are out of my price range. But I'll ask Greg about PCBs.
How sensitive are these things to loading from input switching and volume pots?
Old 18th August 2010, 09:20 PM   #5
keantoken's Avatar
Class D amps are designed for efficiency, not sonics. An analog solution would probably be more fitting. Many people in fact try to avoid chips... But that is the purist approach.
I usually see a 50k input pot being used in amps. Usually there is a high-value resistor right at the input, to precharge the input cap which prevents loud pops when switching. Apart from this I've never heard complaints about volume controls. However for purists there are "constant impedance" stepped volume controls...
- keantoken
Old 18th August 2010, 09:58 PM   #6
theAnonymous1 is offline theAnonymous1  United States
theAnonymous1's Avatar
Ouch.... that was unnecessary.
Old 18th August 2010, 10:24 PM   #7
keantoken's Avatar
Okay, I'll rewrite that a bit. Yes they are designed to sound good, they must to sell. But from what I hear, they still don't compete with the analog alternatives. So if you don't need the efficiency, why would you even consider one? This was my line of logic.
Opinions are scary, yes they are,
- keantoken
Old 18th August 2010, 10:33 PM   #8
gaetan8888 is offline gaetan8888  Canada
Hello
I agree with keantoken, a very well designed analog amp will have more musicality, a better sound stage and a more engaging sound compared to a class D. For sure you need to use an excellent cd player and well recorded music cd to ear the differences.
Class D are still a young design compared to analog amp, so we will see how they will develop in the future.
Bye
Gaetan
Old 18th August 2010, 10:41 PM   #9
TheDealer is offline TheDealer  Germany
Bye
Gaetan
good morning Sir ! My greetings to the midle-ages ....
Old 18th August 2010, 10:48 PM   #10
Hello
Do some serious blind tests listenings of some the best high-end analogs amps compared to the best class D amps, you will ear the differences, class D sound much less musical compared to the best high-end analogs amps.
No need to tell more, since the thread are not about that.
Bye
Gaetan
New to this -- recommend a good ~50Wpc board?Hide this!Advertise here!
STK 4191V amp chips 50wpc 7pcs $20 homemade Swap Meet 2 18th July 2005 07:54 AM
Pls recommend a good class-A goldyrathore Solid State 24 15th July 2005 04:50 AM
Can anyone recommend a good buffer circuit primalsea Tubes / Valves 9 23rd November 2004 10:58 PM
Can you recommend some good Mocacor tweeters? mr_push_pull Multi-Way 10 27th September 2004 11:15 AM
