Go Back   Home > Forums > Amplifiers > Class D
Old 17th August 2010, 05:36 PM   #1
Default connex TA3020 v3c
Hello all,
Ive bought and built 4 connex TA3020 V3C's (tripath 3020 chip) using the suggested smps modules made by the same company.
They sound realy good and im very happy, but I would like to try and get the noise floor just that little bit lower to make the amp perfect to my ears.
What can I do to drop the floor??
Thanks all.
Old 17th August 2010, 06:15 PM   #2
ps- I have a little bit of a squeek/squeel sound from one of the modules - not much above the noise floor - but it is there. Any ideas what this is?
Old 17th August 2010, 07:47 PM   #3
r0b is offline r0b  Germany
absolutely no Pro on the topic or on the modules, but just looking at it I would suggest trying an enclosure that might shield the setup a bit more. To try if it does anything, move the setup far away from any source of radiation. (Which might prove to be quite challenging...)
r0b
Old 17th August 2010, 09:34 PM   #4
Ok,thankyou.
thats a start.
The modules are going into a enclosure at some point- I made the rack you currently see to evaluate and make any changes needed before I started messing around with cutting enclosures etc.
I was thinking of separating the smps from the amp module with a aluminium wall or somthing like that- was thinking of star earthing or somthing like that??
Old 18th August 2010, 12:32 AM   #5
col is offline col  Australia
col's Avatar
I agree with Rob also, you have the speaker wires crossing the power cables from the SMPS into the amp module? I wouldn't start changing components on the amp module unless you REALLY know what you are doing. Are you on the ConnexElectronic Class T thread?
col.
http://www.minirig.org.au
Old 22nd August 2010, 10:03 PM   #6
just a qick update- I moved the cables and the high pitched noise has gone.
Im looking to try bridging 2 of the amps next- do I just solder the point up or do I have to put a resistor in it or somthing?
where to I take the speaker out from when its bridged?
Connex Electronics TA2022Amp eelind Class D 2 22nd February 2011 01:26 PM
15000ufx6 63v Connex PS wushuliu Swap Meet 1 17th June 2010 02:59 AM
Building Connex NXP amp Kjeldsen Class D 1 8th April 2010 08:04 AM
TA3020 HELp!!!!!!!!!!!! TeamAmped! Chip Amps 5 25th September 2009 04:25 PM
ta3020 marios Parts 0 31st January 2005 08:35 AM
Page generated in 0.07146 seconds (83.95% PHP - 16.05% MySQL) with 10 queries
