Go Back   Home > Forums > Amplifiers > Class D
Old 14th August 2010, 04:08 AM   #1
Default amplify low frequency signal
Not sure if this is the right place to ask this question.
I am trying to amplify a 0-1000 Hz sin signal to drive a 8 ohm EM load. I need the output power to be at least 20 W. Can a class D handle the job?
I saw all the specs only go down to 20 Hz.
Also, I would like the output to be zero if the input is zero.
Perticularly, can this
http://focus.ti.com/lit/ug/slou208/slou208.pdf
or this
http://focus.ti.com/lit/ug/slou210/slou210.pdf
work?
Thanks a lot in advance.
Old 14th August 2010, 05:29 PM   #2
Send a message via Yahoo to Th3 uN1Qu3
The amps have input coupling capacitors. By increasing the value of those you can lower the low frequency cutoff. It shouldn't be a problem getting linear response down to 1Hz but you will also have to increase the power supply capacitance to have the amp deliver full power at such a low frequency.
"Audio grade" components simply means that they failed at a more critical job.
Old 14th August 2010, 05:41 PM   #3
Pafi is offline Pafi  Hungary
Yes, but you need a DC coupled, bridged amplifier.
Old 14th August 2010, 06:26 PM   #4
...and Pafi is not just joking.
Full bridge is a key for DC-signal-applications, otherwise you will suffer from heavy rail pumping.
(A half bridge topology for DC-signals would demand a power supply, which can source and sink - normal power supplies can source only.)
Old 14th August 2010, 08:12 PM   #5
Thank you guys!
Old 15th August 2010, 06:59 AM   #6
Thank you.
weak input signal to amplify pra3718 Chip Amps 2 14th January 2009 02:29 PM
amp with single input can't amplify pulse signal,please help me thanh Solid State 2 26th October 2004 01:56 PM
Can amplification based ta3020 amplify direct current signal? green3002 Class D 0 14th October 2004 06:01 AM
tapping low frequency signal from a creative 2400 sub csthiang Solid State 1 13th April 2004 05:36 PM
Amplify weak signal to stronger... Mikka Solid State 18 8th June 2003 03:12 AM
Page generated in 0.07608 seconds (73.07% PHP - 26.93% MySQL) with 10 queries
