Go Back   Home > Forums > Amplifiers > Class D
Old 4th August 2010, 03:04 PM   #1
Default Budget Boominator "lite".
I have acquired the components for a mobile mini PA and am about to start construction on the works. My design parameters have centered around trying to balance cost/weight/SPL but I still have to choose a battery, any suggestions?
Lead acid is very cheap ($30 for 24v 7ah) but kind of heavy.
What is the cheapest lithium battery that will drive the Sure Amp at full power for 4-6 hours?
Components:
Amp Sure Electronics 2X100 board $40
Speakers Peavey Pro 10 neo $40 X 2 = $80
24 piezo tweeters $24
5' of 10" sonotube (Free)
I also have a case of these 5" neo drivers I can array, although the lower efficiency might not add much to the project, at $3 each with grill I could not pass them up! 8 X $3 = $24
This will be the second "boom bike" I have constructed and be used to promote the local science museum.
Trying to keep the project under $225, that gives me about $60 for a battery.
Old 5th August 2010, 12:49 AM   #2
Bump to any in the know.
Old 5th August 2010, 08:49 PM   #3
gfiandy is offline gfiandy  United Kingdom
Audio Engineer
gfiandy's Avatar
A very rough and ready calculation.
Full power music = approx 1/8th of max power (otherwise it will be so clipped you can't listen to it due to crest ratio of music)
Assume amp efficiency is 80%
Power = 100W / (8 * 0.8)
=> 15.6W per channel
2 channels
=> 31W
24V supply
P= IxV => I = V/P
=> I = 24 / 31 = 0.77A
playing time 6 hrs
=> 6 x 0.77 is required capacity => 4.6 amp hours required
Cheaperst lithium Ion I could find (with no charger) £138 but I didn't spend long looking.
I'd recomend you go with the SLA or even a slightly smaller one.
I can't guarantee this calculation it has some pretty rash assumptions in it, you didn't give me much to go on.
Andrew
Old 5th August 2010, 09:12 PM   #4
Rebel Samurai!
AdamThorne's Avatar
Just a note for refinement on gfiandy's estimate:
80% efficiency on that amp sounds about right, but it only outputs 30-40 watts per channel at reasonable distortion levels into 8 ohms.
If he's using the amp I'm thinking of, anyway.
2*100W@ 4ohm TK2050 Tripath Class-T Audio Amplifier Board, Upgraded of AA-AB013 Buy Two Get One Free_Audio Amplifier and other Audio Boards_RF and Audio, Video Equipments_Sure Electronics' Webstore
so -- no promises here! -- 4.6 amp-hours might be more than you need to hit your target.
Old 6th August 2010, 01:15 AM   #5
Thanks, it looks like I am on track and will share pictures soon!
Old 24th August 2010, 12:20 AM   #6
Just needs to be wired up!
Old 24th August 2010, 09:10 AM   #7
r0b is offline r0b  Germany
Sweeeeeeeeet
You could make it steampunk style, taht would fit with the science museum thing.
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
"Budget" GM70 SET sorenj07 Tubes / Valves 60 22nd October 2009 06:40 AM
Kofi Annan in: "Givin' a Budget 'Table!" Kofi Annan Analogue Source 29 14th August 2008 11:14 AM
Surprising Output from a "budget" project musgofasa Subwoofers 10 19th March 2008 05:13 PM
Your ideal "ChipAmp", unlimited budget loong Chip Amps 23 12th February 2004 11:56 PM
Page generated in 0.09862 seconds (79.05% PHP - 20.95% MySQL) with 10 queries
