| Class D Switching Power Amplifiers and Power D/A conversion |
Hi everybody,
going to finish this class-D amp shortly. power amp - TAS5261 Silver plated PCB controller - PCM1808+TAS5010 anybody intrested ? Going to post schematics soon! Thanks |
#2 |
Nice!
![]() But how on earth did you manage to solder that fine pitch components ?
#3 |
0.5mm pitch is easy; it can be done with a standard tip (in good shape).
"If you don't like funerals don't kick sand in Ninja's face." - Ninja |
#4 |
And im having throuble soldering regular DIL package, occational bridges.
#5 |
how you coated silver over track
#6 |
#7 |
#8 |
This looks very interesting
![]() Solding surface mount parts isn't all that hard. Even the smallest parts can be handled with relative ease, the trick is to use solder wick/mop. Simply flood the pins and pads beneath them, then suck up all the excess solder. Usually that's enough to get the job done. I can soldered SSOP without bridging any of the pins, but then I do have a 0.6mm soldering tip if needed. The trouble when things get that small is effective heat transfer.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack! |
#9 |
what's up with this amp, working?
| PWM Controller ICs Choices | Top_Gun007 | Power Supplies | 3 | 14th April 2010 09:20 PM |
| Full Bridge PWM controller w/ Integrated Gate Drvrs | TechGuy | Power Supplies | 3 | 8th January 2009 01:30 PM |
| PWM controller for DC servo motor? | space-cake | Analogue Source | 3 | 18th October 2008 03:20 PM |
| Help selecting PWM controller | eeka chu | Class D | 8 | 25th May 2004 10:00 AM |
| PCM1804 -> TAS5015, Analog PWM amp | fr0st | Digital Source | 0 | 26th August 2003 12:59 PM |
| Page generated in 0.10783 seconds (75.89% PHP - 24.11% MySQL) with 11 queries |
