Go Back   Home > Forums > Amplifiers > Class D
Old 4th August 2010, 08:43 AM   #1
Default Problem with Kingrex T-amp
I was fiddling with my speaker cables the other day and when I stood up I noticed my amp Kingrex T20 t-amp and PSU had stopped working. Opened up the amp and found nothing wrong that I could see. Opened the PSU up and found one dead fuse. Unplugged all the cables, wrapped the fuse in aluminium foil (temporary solution, not recommended!) and fired it up again. All lights come on then i can hear a single click from the amp (protection circuit?) and the LED turns off. The PSU light stays on for about 10 seconds then slowly fades as well.
If I fire up the PSU without the amp connected, it stays on so im assuming the problem is with the amp and not the PSU?
Here's some pics inside the amp from another site: http://www.6moons.com/audioreviews/kingrex/t20.html
Any ideas fellas?
Old 4th August 2010, 02:56 PM   #2
Pano is offline Pano  United States
Pano's Avatar
I've never seen one blow a fuse! Usually they just go into protection mode themselves.
Check for short circuits inside the amp. Bad or broken wire? Piece of metal or something touching somewhere? Traces look OK? Are the speaker terminals shorted to the case? That sort of thing.
That will give you something to look for until someone else who has had the same problem posts here.
Take the Speaker Voltage Test!
Old 4th August 2010, 05:22 PM   #3
frugal-phile(tm)
planet10's Avatar
Ours didn't blow fuses. Just T-amp chips... 2 so far.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 5th August 2010, 02:32 AM   #4
t-head is offline t-head  United States
if you shorted your +/- speaker wires, the chip is probably toast...been there done that...
trust, but verify...
Old 5th August 2010, 11:36 AM   #5
Everything inside looks ok, any way to know that the chip is blown? Is it easy enough to plonk in a new chip?
Old 5th August 2010, 01:19 PM   #6
Solve is offline Solve  Sweden
Solve's Avatar
I have done that, not so hard to fix.
One ugly way to do it:
Dead Kingrex amp
Music is the only art in real time....
Old 8th August 2010, 09:21 AM   #7
Dead Kingrex amp
Impressive soldering! I imagine that must have taken a while. Where did you find the spare chip?
Old 8th August 2010, 09:06 PM   #8
Solve's Avatar
Its not so hard to fix with a thin soldering tip.
With my way to do it its much simpler than remove all legs and use soldering wick.
You can cut the legs also, not wick it like i did.
Chips:Connexelectronic
Dead Kingrex amp Nappyhead Class D 15 20th March 2010 04:05 PM
trends audio TA 10.1 audiomagus mod or Kingrex T20 Tripath amp andywhale Class D 5 17th February 2009 06:21 PM
Got a Kingrex T20U. I'm impressed gnugear Class D 0 21st May 2008 05:18 AM
Sony HT vrs KingRex jleaman Solid State 13 25th December 2007 11:54 PM
Want to build a 12V PS like the KingRex phrarod Chip Amps 19 24th December 2007 08:01 PM
Page generated in 0.09105 seconds (78.63% PHP - 21.37% MySQL) with 10 queries
