Go Back   Home > Forums > Amplifiers > Class D
Old 2nd August 2010, 01:16 AM   #1
ppia600 is offline ppia600  United States
Smile SA-15 S.M.S.I. Mini ta2024 12v amp, need higher input sensitivity...
I asked in the lepai 2020 thread but no help so far so here is my thread dedicated to this: TA2024 mini Class T Amp Mini HI-FI Stereo Amplifier #1 - eBay (item 270547118593 end time Aug-11-10 14:34:19 PDT) mini amplifier.
Very low priced for a complete amp and very compact. I plan on using it at work to power two 5.25" sony speakers and will be running it off my zen mp3 player and 12v4A power supply.
It seems to have very low input sensitivity as running it with my portable mp3 player was very disappointing so I plugged my home dvd player outputs into it and VOILA it sounds a LOT louder and is still very clean.
Could someone point me in the right direction on correctly modifying the input circuit in this amp to substantially increase sensitivity so I don't have to buy or rig some kind of preamp? I'd like to maintain the clean sound of this thing and have as few components as possible. Thanks for any help
Don't worry... you can always turn the gain down!
Old 2nd August 2010, 01:34 AM   #2
Default some crappy pics
Old 2nd August 2010, 09:05 PM   #3
theAnonymous1's Avatar
Page 7......
http://www.datasheetcatalog.org/data...h/mXyzxwwt.pdf
"If you don't like funerals don't kick sand in Ninja's face." - Ninja
Old 3rd August 2010, 01:45 AM   #4
Thanks, that's two references to the datasheet so I'll give it a shot.
Old 16th August 2010, 03:27 AM   #5
Well the closest thing I could find to RI was the one I took out and replaced with 200ohms (two series 100ohm). It was originally 20k ohm. Seems to work fine but now of course I have hiss with the amp volume knob all the way down or at anything past 3/4. I put it at a little less that 3/4 and the gain is perfect so I can control it with the mp3 player. It should work well enough in our noisey shop. I'm also replacing the four .22uf caps on the output side with .47uf as per the circuit diagram and changing the two 1/4watt 10ohm on the outputs with 1/2 watt versions. Hopefully it will still sound nice. I'm also thinking of installing a thick silicone conductor pad on the bottom to transfer some heat through the sink.
Resistors I soldered in:
Area that will be getting slightly different values:
Thanks for the help guys, now let's see if this little beast can stay alive for a while.
Old 28th August 2010, 09:23 PM   #6
Replaced the .22's with .47's and upped the two resistors to 1/2w per datasheet. Now I'm wondering if the bias needs to be tampered with. Still sounds very nice, now I have to get the ported boxes made for the 5.25" sony coaxes.
input sensitivity too low on PA-amp skogs Solid State 16 11th October 2007 10:47 AM
Math to calc optimal voltage of tube dac to match amp input sensitivity? riotubes Tubes / Valves 7 9th November 2006 11:08 PM
Input sensitivity on amp? suspencefull Solid State 25 3rd September 2006 07:44 PM
How to raise input sensitivity on power amp? jazzpeter65 Solid State 5 15th December 2003 11:59 AM
Leach amp input sensitivity Has Solid State 6 4th November 2003 08:14 AM
Page generated in 0.09533 seconds (78.22% PHP - 21.78% MySQL) with 10 queries
