Go Back   Home > Forums > Amplifiers > Class D
Old 30th July 2010, 09:22 PM   #1
Default Sure TK2050 and Phono Stage
I have a Graham Slee phono stage plugged into my sure tk2050 (tripath) amp with a 100k ohm pot in the middle. Even with the pot at nearly maximum resistance and the gain switches off on the amp board, it's pretty loud. If I plug an iPod in instead, then the volume is much more appropriate.
Is this perhaps the phono stage putting out higher voltages than the iPod, and might I be able to remedy this with a more resistant volume pot or is there some other solution?
It's a Gram Amp 1 stage incase that helps...
The Phono Stage Peter Daniel Audio Sector 391 Yesterday 12:02 PM
Phono Stage Jamesuk1 Tubes / Valves 7 9th November 2009 11:26 AM
DIY phono to replace roksan phono stage seroxatmad Analog Line Level 6 14th December 2008 05:46 PM
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 09:51 PM
Should I replace Scott 222C phono stage with Claret phono stage? Bing Yang Analogue Source 0 22nd August 2005 06:41 AM
Page generated in 0.07518 seconds (68.94% PHP - 31.06% MySQL) with 10 queries
