Go Back   Home > Forums > Amplifiers > Class D
Old 26th July 2010, 05:45 AM   #1
Default chip burn-out when plug-in or plug-out DVD signal lines
I've designed a class-d amplifier with one internal LDO. when I plug-in or plug-out DVD signal lines, the chip is ease to burn-out. if I add one zener(5.7V) between LDO output and ground, everything is ok. I don't know why this happen? please give me some suggestion to find this cause, thank you! Kenneth
Old 26th July 2010, 12:13 PM   #2
m-tech is offline m-tech  Serbia
Too much capacitance on LDO output ?
Adding a diode from output to input can solve this problem.
Old 28th July 2010, 11:46 AM   #3
m-tech, thanks for your suggestion.
I've try your solution:
1) add 1 schottky diode between LDO output and Vin, it's improved, but finally it's also broken.
2) change LDO output capacitor from 1uF to 0.1uF, it's also improved, but it's also broken finally.
could you please explain your original idear in detail?
my design is high-power class-d audio amplifier. if add external schottky between output and gnd, and add 1 zener between LDO output and gnd, everything is ok. I'm not very clear about the root cause.
Old 3rd August 2010, 05:07 AM   #4
Hi, all,
I have more testing for this problem. when it occurs, ldo output will fly to 10V, and then it will latch to 3V(normal is 5V). I don't know what happene for the internal circuit. please give your experience, thank you!
RTA plug-in pjanda1 miniDSP 4 15th July 2010 09:20 AM
Plug-in Updates minidsp miniDSP 1 22nd April 2010 06:01 AM
WTB: 2.5mm plug to 3.5mm plug cable Relax Swap Meet 5 10th February 2007 12:13 AM
plug for amp karma Everything Else 12 24th April 2004 07:53 PM
better than bullet plug? overmind Parts 1 29th April 2003 03:55 PM
Page generated in 14.92499 seconds (0.53% PHP - 99.47% MySQL) with 10 queries
