Go Back   Home > Forums > Amplifiers > Class D
Old 25th July 2010, 09:14 PM   #1
Default High Powered classdaudio.com amp?
I'm interested in a dynamic, high-powered (500+ watts/channel), amplifier for my system, and there are a few options available on their web site:
TI-600 Kit plus a second TI-600 amplifier module, for 600 watts/channel @ $390
CDA-1000 Kit , for 500 watts/channel @ $325
CDA-258 Kit plus a second CDA-258 amplifier module, for 1000 watts/channel @ $450
It's a bit confusing because some of the descriptions aren't clear...
Originally Posted by www.classdaudio.com CDA-258 Kit
Package deal includes 1 of our most powerful 500W X 2, or 100W X 1 Class D Power Amplifier modules, Large Power Supply, 500VA AnTek Toroidal Transformer, and transformer mounting kit. This is a great combination of components for a complete audiophile quality power amplifier. The power supply included in this kit is capable or running two amplifier modules. With the included components you can build a 1000W 8 Ohm stereo amplifier or 4 channel X 500W 4 Ohm or 4 X 250W 8 Ohm.
Another confusing note...
Originally Posted by www.classdaudio.com CDA-258 Amplifier
Specifications:
· Output: 250 X 2 - 8 Ohm, 250 X 2 - 8 Ohm
· Bridged Output: Not Recommended
Will it do 1000 watts bridged as suggested in the CDA-258 Kit?
Looking at the differences between the CDA series and SDS series boards:
Our new Super D Series audio power amplifiers are built on the highly acclaimed reputation of our CDA series amps. Our goal was to keep the excellent sonic qualities while adding a state-of -the art balanced input stage (also accepts standard single ended input) and external adjustable gain controls. We've also added a better cooling system, Molex connectors for external LED's, power switch, and gain controls (included). The balanced input stage is one of the finest available and normally only found on very expensive high-end equipment.
I wonder if it's worth the cost difference for me(?) I don't plan on running a balanced input, nor do I feel the need for adjustable gain, as my pre-amp, an Audio Alchemy DLC, doesn't offer balanced output, and runs passive until 0dB and then goes into an active mode. I also have a Musical Fidelity X10-D line buffer that I thought I'd hard-wire, build into, the amplifier as an input buffer, so the lower input impedance of the CDA boards shouldn't be a concern.
Any thoughts or guidance is greatly appreciated.
Maybe Tom 9classdaudio-usa) has time to chime in(?)
Regards, Barry
Old 26th July 2010, 02:26 AM   #2
tinitus is offline tinitus  Europe
hey Barry, what is impedance of your speakers, thats important
Supply voltage rating is the key
yes, a lot of info about multiple options, and slightly confusing
maybe it would be easier to explain and understand if all that info were put into a form/framework
when it says bridged not recommended, it could mean not at the suggested max voltage
but might still be fine bridged at the lower voltage rating
also remember that any bridged amp will see 8ohm as a 4ohm load, thus it may help to lower supply voltage a bit
nothings for free
Old 26th July 2010, 05:25 AM   #3
Thanks for the reply tinitus. My speakers are rated @ 8 Ohms, so I guess it should be safe to run the amplifier in bridged mode. While I can use a multi-meter, and have a basic understanding of capacitors and resistors, I am far from understanding electronic amplification circuits. So these kits, which come with preassembled boards, are pretty apealing to neophite like myself.
High Powered 3cx300a1 Tube Amp BlackUnikorn Tubes / Valves 22 21st June 2006 12:17 AM
Questions on building High-Powered subwoofer Amp. EWorkshop1708 Solid State 10 30th July 2005 05:57 PM
High powered amp suggestions. Hayden Solid State 9 10th November 2004 04:10 PM
High powered amp choice Mr Teal Solid State 17 6th September 2004 04:59 PM
Page generated in 0.07534 seconds (77.68% PHP - 22.32% MySQL) with 10 queries
