Go Back   Home > Forums > Amplifiers > Class D
Old 25th July 2010, 09:24 AM   #1
Default Tekko plans UcD
I started thinking about building a class d using only discrete components.
Heres the first draft:
Note that its single sided since i had requests of also releasing my layouts as just single sided.
Im gonna redo it as double sided later on.
Old 25th July 2010, 06:39 PM   #2
Double sided version:
Old 25th July 2010, 07:54 PM   #3
darkfenriz's Avatar
Why everything though-hole???
Where are the gate resistors?
P.S. forget about single layer
Old 25th July 2010, 08:43 PM   #4
Heres the original schematic:
http://www.nxp.com/documents/user_manual/UM10155.pdf
Heres my schematic:
Why all through hole ? Because i dont have any smd components and due to my budget i have to make do with the components i already have.
Old 26th July 2010, 05:03 AM   #5
MOER is offline MOER  United States
Default Ucd
The inductance of leaded parts will hurt your design. It is almost impossible to obtain a stable amplifier with good performance with leaded parts.
Steve
Zed Audio
Los Angeles CA
Old 26th July 2010, 06:56 AM   #6
I know that! Now i dunno what switching frequency RX5's amp was but his worked just fine with all though hole components so i figure mine should too.
My amp will have a designed max power output of 30 watts with 18V rails.
Anyways if it doesent work out i always have that other design to go with.
Old 26th July 2010, 08:42 AM   #7
stewin is offline stewin  Kenya
nice work tekko i've experimented on ucd's but i used stripped boards. i liked the sound but i got problems with output fets heating . but when i reduced the value of r15 and r17 sought of solved the problem. here is another scheme i found quite amazing with protection and op amp input
Old 27th July 2010, 08:49 PM   #8
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
It can work with leaded parts, but it will radiate much more RF, increasing the chances of disturbing or increasing the noise floor of other circuits near.
Avoiding it to disturb itself is just the first step.
"hi-fi grade" low EMI can only be achieved with SMD and two or more layers in the PCB.
I use to feel like the small child in The Emperor's New Clothes tale
Old 27th July 2010, 09:06 PM   #9
SMD is actually just pushing it all up in frequency just like you wrote about those directfets some years ago.
Now the leads would be really short much like the legs on a IR2010 but i guess its the quantity, 2-3 legs per component, but the pcb traces are like 10x longer both on my version and on a smd version.
Anyways im prolly gonna go with the LM311 and IR2010 design in the other thread first, and maybe do some experiments with the bca topology.
Old 30th July 2010, 07:13 AM   #10
hi tekko what frequecy are you using ?
UcD 180 or UcD 400 with +/- 48VDC supply Ray Weikel Class D 17 7th March 2009 06:11 AM
Another classd from Tekko Audio Labs Tekko Class D 49 3rd December 2007 06:51 PM
In need of some plans DanielRyba Multi-Way 5 28th October 2007 05:10 AM
looking to upgrade 8 ucd 180st to ucd 180hg mazurek Swap Meet 6 31st May 2007 12:47 PM
Plans so far Mat_89 Multi-Way 7 27th September 2006 03:56 PM
Page generated in 0.10120 seconds (76.23% PHP - 23.77% MySQL) with 11 queries
