Hypex UCD400 OVP problem
Old 23rd July 2010, 09:44 PM   #1
ekaerin is offline ekaerin  Sweden
ekaerin's Avatar
Default Hypex UCD400 OVP problem
Hi all,
I have just finished an ultra compact amp with Hypex modules.
The amp consists of 2 UCD400 amps and one SMPS400.
Pity is, I bought everything at the same time at HiFi kit here in Sweden, thinking the parts would be compatible.
However the SMPS puts out about 70Vdc at my nominal line voltage which is 239Vac tripping the OVP on the amps.
It seems the on board caps and power FETs can handle the 75V limit the higher serial numbers have.
Is there a quick fix I can do ,without risking the modules, to set the OVP to 75V nominal.
Also I would like Hypex to include in the SMPS datasheet the maximum external cap the supply can handle
without the current limit inception to kick in making the startup ramp non monotonic.
I added 4x4700uF and it restarts at least once.
Regards / Mattias
Old 23rd July 2010, 10:01 PM   #2
ekaerin's Avatar
Default And some pics.
The amp will be some 200W / liter.
I may have to squeeze in a small fan but it seems to be OK so far....
Old 24th July 2010, 08:44 AM   #3
luka is offline luka  Slovenia
luka's Avatar
aren't those modul for ~+/-60
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Old 24th July 2010, 11:31 PM   #4
Yves Smolders is offline Yves Smolders  Belgium
Any reason for those additional caps? I was playing with the idea also to make a really small amp.
This case: LEX COMPUTECH - Product
It's a PC manufacturer but I have gutted one of their cases I had lying around. Pure Aluminum, heavy, pretty. I tried to contact the maker to see if they sell the enclosures only.
This can easily house a mono SMPS+UCD400, even stereo one (with one SMPS)
Old 25th July 2010, 07:06 PM   #5
ekaerin's Avatar
Yes luka they probably are. New versions are Hypex smps comp.
Old 25th July 2010, 07:24 PM   #6
ekaerin's Avatar
Yves. I had the caps already and wanted to use them. Dunno the impact but they sure help lowering the supply impedance.
The cases looks good. I looked in to computer cases too.
Mine was an old modem. Just made the panels.
Rgds/ Mattias
Old 19th September 2010, 03:44 PM   #7
Someone at Hypex told me that the "old" modules can be adapted with changing 2 components on the module.
Old 20th September 2010, 06:30 PM   #8
ekaerin's Avatar
Yves. That is correct, Hypex support told me too. I just had to ask them.
Hats off !
/ Mattias
Hypex UCD400 OVP problemHide this!Advertise here!
Hypex UCD400 poweramp (with tube preamp) carrejans Class D 2 9th May 2009 06:35 PM
How can I recognize an Hypex UCD400 from an UCD180? zigo3 Class D 6 25th March 2009 11:53 PM
My hypex UcD400 based amp dagoose Class D 3 27th May 2008 06:00 PM
Hypex UcD400 reviewed peranders Class D 41 5th October 2006 12:16 AM
Hypex UcD400 3-channel $1,200 Al Garay Swap Meet 1 10th November 2005 06:49 AM
Copyright ©1999-2017 diyAudio
